First post, by Trigger58
Hello,
i play a little bit with DOSBOX (latest version) and if i try to switch between fullscreen and window mode, this doesn't work anymore with Windows 11.
In Windows 10 all worked fine but i had to change the OS to Windows 11 and there it doesn't work.
Fullscreen line in dosbox.conf works but it doesn't help if you need to switch and then you can't return into fullscreen mode.
Now if use dosbox-x and with F11+F all works fine.
Any solution how i can get Alt+ENTER with dosxbox to work again?
Reply 1 of 2, by keenerb
Trigger58 wrote on 2022-10-25, 07:21:
Hello, i play a little bit with DOSBOX (latest version) and if i try to switch between fullscreen and window mode, this doesn't […]
Hello,
It works OK for me on windows 11.
