Reunion problem
First post, by Boksi
I've been having a bit of problem with Reunion lately. I don't know what kind of motherboard I have, but I do know I have 2.40 GHz Celeron processor and 256 MB of RAM, I think my video board is called "Intel Extreme Graphics 2", I know I have a "SoundMAX Integrated Digital Audio" something, and I'm running DosBOX 0.70 on Windows XP. I'm at 1280 x 1024 resolution, and set the sound settings to Sound Blaster Pro. The problem occurs sometimes when I'm in the galaxy map, with a vertical line of completely off-colour pixels appearing right below the, uh, taskbar I suppose it's called. The thingy with the icons. Some horizonal lines also appear, usually just one or two. And when I try to move to another screen, like a planet surface or back to the main screen, it crashed and displays this:
External or internal error!
Error code: 10320423
Error address: 0:3631
So, can anybody help me? I haven't found any mention of this error anywhere, and the only way to avoid it is not to use the galaxy map, which is pretty much impossible.
:3
Reply 1 of 5, by wd
Rank DOSBox Author
DOSBox Author
Try using loadfix before starting the game. Does the crash happen, too,
if you completely disable the sound emulation?
Reply 2 of 5, by Boksi
Neither disabling sound nor Loadfix worked, sadly. Crash happened nevertheless.
:3
Reply 3 of 5, by wd
Rank DOSBox Author
DOSBox Author
Could be that the savegame is broken, you'd have to start a new game in
this case (and use loadfix every time you play the game).
Maybe attach your savegame here.
Reply 4 of 5, by Boksi
I don't have any time to try a new game, but I'll attach the savegame.
Edit: Or rather, I would, if I could. I says that "The Extension 1 is not allowed". And now I gotta go, and won't be back for quite a while...
:3
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
You can zip/rar it and attach it then.
