First post, by envagyok
As i know Soundblaster pro2 isn't mpu-401 compatible, so no midi sound outputting via Roland sc-55.
But i see advertisement from 92, and there i see sb pro2 with midi cable and sequencer.
Sadly no picture from sequencer.
Can someone post a picture from sequencer?
Or list what sequencer support sbmidi?
Creative maked it?
http://www.mediafire.com/convkey/74f0/au832rp … g.jpg?size_id=d
Reply 1 of 5, by darry
When running Windows with proper sound blaster pro drivers installed, any Windows native sequencer will work.
At least some DOS versions of Cakewalk supported the Sound Blaster MIDI interface. There are likely others too.
Reply 2 of 5, by envagyok
darry wrote on 2022-11-09, 06:40:
And what about DOS Games with MIDI Sound?
How can utilize SB Pro2 ?
Reply 3 of 5, by Falcosoft
envagyok wrote on 2022-11-09, 09:28:
You can try SoftMPU with the /OUTPUT:SBMIDI command line switch.
SB Pro2 cannot work when GM/SC-55/MPU-401 is selected as output for music in DOS games.
You either need direct support for SB MIDI mode or you need a TSR like SoftMPU.
Otherwise you can only utilize the onboard OPL3 FM synth for music.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 4 of 5, by envagyok
I'm sorry.
It would be nice to have a patch for it, like for the Gravis sound cards.
Reply 5 of 5, by mkarcher
envagyok wrote on 2022-11-09, 13:22:
I'm sorry.
SBMIDI (MIDI via the sound blaster port 22x) is handled by the same processor (Creative calls it DSP, but it's not a DSP in the classic meaning, just a 8051 that implements most of the card orchestration functions) that also handles digital audio. It can not handle both at the same time, so using the MIDI port of the Sound Blaster or Sound Blaster Pro means that you can't use Sound Blaster digital audio at the same time. That's why it is mostly unsupported in games - those games don't want to give up digital samples.
