Reply 60 of 61, by dionb
- l33t++
MrMateczko wrote on 2022-11-15, 22:57:22kHz vs 44kHz sound effects difference sound (ha!) like a minor tradeback for me for having good DOS compatibility from a reasonably priced ISA card.
Which DOS compatibility issues are you having with the CM8330? Its compatibility is generally excellent, there's a reason that chip is being used for a modern ISA sound card (MK8330) considered to be possibly the best all-round ISA card you can get. On your motherboard it's not on an ISA card, but it's on the ISA bus, so will function as fi it was.
