First post, by moulder
I have problem with Interstate 76. After few minutes it hangs and show error "interstate 76 grtexdownloadmipmap mipmap cannot span 2 Mbyte boundary". What could be cause?
My spec: PIII 700 MHZ, 2x Voodoo 2 in SLI, 256 Mb ram. I 've installed newest patch for I76.
Reply 1 of 2, by leileilol
Disable SLI and limit texture memory to 2MB. You could also run it in Direct3D which would be fine at the expense of hand texture resolution
Debian's fucked
Reply 2 of 2, by moulder
leileilol wrote on 2022-11-30, 01:19:
Now it seems ok. Thank you.
