lighthouse
First post, by abyss
Thos was an awesome game from sierra. The problem is that it won't run without dosbox but once it gets to a part where you need to switch the disks with dosbx you can't switch disks so it is impossible to get very far with dosbox on lighthouse. Does anyone know of a way to fix the problem. I can't put all the disks into 1 disk as it will never fit into 1 disk. Is their a way to be able to switch disks when you need to for lighthouse.
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
Depends on how you mounted the stuff. See ctrl-f4 in the readme,
along with mounting floppy images.
Reply 2 of 6, by abyss
It uses multiple cd roms not floppy disks.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
wait for the next version. (if you use isos)
else mount all cdrom at different drive letters.
Water flows down the stream
Reply 4 of 6, by Tiberius440
im only finding that problem at the switch when taking the ornithopter for the first time from the tower fortress to the temple. im using dosbox. i didnt have any problems with the switch between the lab to the beach.
are there any save games anywhere online that can be downloaded to overcome this issue?
or is there a quick fix
Reply 6 of 6, by abyss
That means i don't have to make multiple drives oe use iso. I can just download a save that is right after the disc change so i can just quit dosbox when i need to change disks and get a game save right after the disc change.
