First post, by haker120
I just got s370 to slot1 adapter without manual and I have no idea how to set it up. Pics of adapter in attachement.
Reply 1 of 11, by PARKE
The jumper settings are printed on the rear side:
The attachment S31rear.jpg is no longer available
Reply 2 of 11, by Sphere478
For setting vcore 😀 setting will vary by cpu.
🤔looks like it doesn’t make the voltage its self, but rather the jumpers send the request to the mobo.
Sphere's PCB projects.
Reply 3 of 11, by haker120
Except it's not? 😁
Reply 4 of 11, by PARKE
Ok, in your case the print is absent. But this is the QDI 3.0 (S3.1) slotket and the settings in the photo above should work.
The attachment QDI3.jpg is no longer available
Reply 5 of 11, by haker120
They do however P3 doesn't work and only Celeron I own is 1.1GHz and I'm not sure that will work. And before I'll confuse anyone, I did set 1.8V as this is the minimum my board accepts. 😀 Works with my other modified slocket1 at 1.8V.
Reply 6 of 11, by aaron158
haker120 wrote on 2022-12-08, 18:03:
what p3 did u use. if its 440bx its best to use one that does 100mhz fsb. also is the bios updated
Reply 7 of 11, by rasz_pl
at first glance it doesn not appear to be FCPGA, might also need modding
Reply 8 of 11, by haker120
I have P3 800 and 900MHz FSB100 both and Celeron 1.1GHz FSB100. I think I have to mod it but do I need to remove 3rd pin or just connect other two reset to VSS?
Reply 9 of 11, by rasz_pl
I just rip that pin out of the socket, Afaik its not used in PPGA cpus anyway. Just make triple sure you are removing correct one 😀
Reply 10 of 11, by haker120
So do I have to or can I ignore this one? My friend told me this pin is unused anyway. 😁 First adapter (from other topic) I moded has it ripped off. 😀
