First post, by theelf
Hi, i need some help, im stuck here
My main computer have a 1920x1080 TFT and a CRT,Windows XP 32bits
Before i have a 8600GT and i use 70hz for dosbox in tft and crt
1920x1080 70hz was working fine, and i was happy in TFT, and im CRT i have all native ones
I upgraded to a ati hd5670, but now im stuck in a maximum refresh of 60hz and no custom res, i dont see nothing in ati panel
even the integrated intel have custom refresh and res option
I tried winmodelines and no luck, im stuck because is my first time with ati beyond old ones
Any ideas? thanks
Reply 1 of 3, by bakemono
Are you using DVI, VGA, or something else? Have Catalyst Control Center installed?
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 2 of 3, by theelf
bakemono wrote on 2022-12-11, 18:18:
I tested in DVI and HDMI, and yes, i have CCC, and 60hz max there. My only options are 25/30 interlaced, and 50/60 progresive. I changed monitor driver (generic pnp, svga, originals and custom 50-75mhz i made with powerstrip) but no change
This TFT with integrated intel and nvidia is up to 75hz, then is not monitor, is the ATI
Thanks
Reply 3 of 3, by agent_x007
Try different/older driver ?
