Reply 4560 of 7240, by Sombrero
- Oldbie
NOD campaign of the original C&C done. I don't think I've played the NOD campaign since the late 90s, I've always preferred the GDI campaign with their stronger units and green grassy maps. In the time between I had become half convinced the NOD campaign is full of annoying guerilla missions where you don't get a base, and even the missions where you do get a base are much less fun thanks to the sad little tanks you get. Also I was sure you couldn't really use the iconic obelisk of light at all because it just gets instantly wrecked by ion cannon/air strike/orcas.
Wrong. Well, mostly wrong. The NOD campaign had a couple more missions where you couldn't just slap the construction yard right where you started and had to take it elsewhere first, but as a whole it had about the same amount of missions where you don't get a base at all. Also I didn't lose a single obelisk during the campaign to anything, you get to use them on the three last missions and I used them on the third last and the last missions. Didn't use them on the second last because one of my turrets got blown to hell by ion cannon and decided to not to build obelisks as a precaution.
The light tanks sure are dingy little toys compared to the tanks GDI gets, they do their job in masses against armor but it was pretty depressing to watch a dozen light tanks trying to kill a single rifleman with little success, but once flame tanks became available it was barbeque time!
So it wasn't as bad as I feared at all. I do still much prefer the GDI campaign just like I prefer the Soviet campaing in Red Alert, but unlike RA's Allied campaign this is something I can see myself playing again in the future.
