First post, by jrichey98
First off I just wanted to say thanks for programming dgVoodoo2. I've used it for years and I absolutely love it when playing old games. It also let's me use ReShade on all old games, which won't work on some by itself. I can use an older version, however I threw something at your PayPal already as encouragement to keep maintaining it, and let you know how much I really appreciate it. Also definitely encourage others to pay it forward as well.
Game: Deus Ex - Invisible War
Issue: There is a double cursor / not disappearing cursor in the 3D rendered part of the game. It's fine upon loading the game, but the first time you go to load a UI element the cursor appears, but doesn't disappear once you exit the screen.
dgVoodoo2 stats: Working <= 2.7; 2.71 <= Broken => 2.79_3
Log: https://drive.google.com/file/d/1M8gqHL4KLDNZ … iew?usp=sharing
Log - Filter "Curser" Include:
0.000000 2022/10/13 03:21:34.029 0 DebugView++.exe File Identification Header, DebugView++ Format Version 1
0.310763 2022/10/13 02:27:35.084 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
2.705350 2022/10/13 02:27:37.479 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 0)
2.727346 2022/10/13 02:27:37.501 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
2.728039 2022/10/13 02:27:37.501 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 0)
14.386653 2022/10/13 02:27:49.160 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
14.386679 2022/10/13 02:27:49.160 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorPosition (this = c078800, XScreenSpace = 1280, YScreenSpace = 700)
14.388905 2022/10/13 02:27:49.163 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
14.389247 2022/10/13 02:27:49.163 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
14.766053 2022/10/13 02:27:49.539 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
14.766520 2022/10/13 02:27:49.540 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
15.139335 2022/10/13 02:27:49.913 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
15.140193 2022/10/13 02:27:49.914 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
15.524356 2022/10/13 02:27:50.298 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
15.524981 2022/10/13 02:27:50.299 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
15.906148 2022/10/13 02:27:50.679 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
15.906788 2022/10/13 02:27:50.680 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 1)
16.273729 2022/10/13 02:27:51.047 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 0)
17.646904 2022/10/13 02:27:52.420 3604 Deus Ex Invisible War.dblog Direct3D8Device::SetCursorProperties (this = c078800, XHotSpot = 0, YHotSpot = 0, pCursorBitmap = defa9c4)
17.647371 2022/10/13 02:27:52.421 3604 Deus Ex Invisible War.dblog Direct3D8Device::ShowCursor (this = c078800, bShow = 0)
Log Analysis:
After loading a save, it does a ShowCursor set to 0. The cursor is not present on screen (other than the center screen graphic). At 14 seconds in was when I was finally able to get over and click something. You can see a ShowCursor 1, followed immediately by a SetCursorPosition 1280 x 700. It shows ShowCursor 1 a few more times, but eventually shows a ShowCursor 0 @ 16.273729, which was caused by me exiting the ui menu. The cursor is not supposed to be present after that. The final ShowCursor 0 at 17.647371 is from me alt-tabbing out of the window.
I tried to capture as little logs as relevant to keep the log size down, however from going into the window multiple times, you enter and it does a ShowCursor 1 and the cursor shows up. When you exit it does a ShowCursor 0 and the cursor doesn't ever disappear after that. There is another game cursor, but I'm pretty sure it is just a reticle drawn on the screen, not an actual cursor as far as DX is concerned. ShowCursor 0 seems to be non-functional.
I've never done any DirectX programming, so I hope I'm not throwing a red herring here. Just trying to do as much on my end as I could to help with the issue.
Sincerely,
--Jem
Edit: Further information discovered. With 2.70 changing ScalingMode from unspecified to centered_af will cause an identical issue. However with 2.79_3 it does it on ScalingMode unspecified as well.
Edit2: Works best with 2.64 or earlier, still had some issues with 2.70. Attached is working 2.64 dgVoodoo.conf & Default.ini from Invisible War (set for widescreen & 2560x1440). No mod's, ReShade is working well.
    Default.ini
    49.38 KiB
    47 downloads
    dgVoodoo.conf
    15.16 KiB
    49 downloads
    1.52 MiB
Reply 1 of 2, by Dege
Jem,
Thanks for the donation and the extensive description for the problem! I'm sorry about checking this issue out and responding to it so late.
Yes, you're right, Direct3D8Device::ShowCursor with bShow = FALSE doesn't work as expected. In the older versions the device cursor implementation was kinda trash (problems with FFXI) so I rewrited that part from scratch. That's when this bug must have appeared in the code.
Now I fixed it and tested with all cases (hardware cursor, emulated cursor), and it works with this game. But of course, it should do it with others too. 😀
Reply 2 of 2, by jrichey98
Dege,
Glad my digging was able to shed some light on the issue. I know this takes time, and the work you've done and shared with everyone is amazing and appreciated. I use it for all my old games.
Sincerest thanks,
--Jem
