First post, by JayAlien
Hi, I have a 386 with a SB Pro 2.0 CT1600.
The volume on the card is very low when I boot the PC, however I can get to a normal volume by firing up \sbpro\sbp-mix.exe and setting all the sliders to max. However these settings are lost on reboot.
Is there a way to make these volume adjustments less volatile, or perhaps a way to set the volume during boot?
Thanks
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 3, by wbahnassi
Yes. If you install the SBPro disks, it will register also an SBP-MIX.EXE entry in AUTOEXEC.BAT to init the mixer to good values. You can also add it yourself. To figure out the switches I think you can run SBP-MIX /?
It will list all options and switches, including the "silent mode" switch (IIRC it was /S) which will set mixer values on the command line without the UI. Just gather all the settings and build the line to put it in your AUTOEXEC.BAT.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 3, by Gmlb256
As the above post stated, a mixer executable should be registered in AUTOEXEC.BAT after installing the software that came with SBPro2 floppy disks. In my case it was SBP-SET.EXE and that one was entirely done with command line switches.
An example:
C:\SBPRO\SBP-SET.EXE /M:10 /VOC:15 /FM:15 /CD:0 /X:0 /LINE:0 /ANFI:OFF /DNFI:ON /Q
Should be put after setting the BLASTER and SOUND environment variables. The /Q command line switch is for silent or quiet mode.
Reply 3 of 3, by JayAlien
That did it, thanks both. Not sure how I installed the software but skipped this step.
I re-ran the installation.
It's all working great now!
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
