Reply 680 of 1104, by NachtRave
- Member
Mu0n wrote on 2022-12-21, 23:16:No slowdowns at all under DOS, even when I transfer a mass amount of files through mtcp's ftpsrv. […]
Duffman wrote on 2022-12-21, 06:38:where do you normally notice the slowdowns?
However, under win98se and transfering large files like CD ISOs or higher is when I notice the alternance between copying slowly for a few seconds, followed by a total pause of 15ish seconds, then another sluggish copy interval of a few seconds, and on and on.
Transfering small files doesn't seem to have that effect or it's not noticeable. It's so terrible for large files that I just do the copying under modern hardware.
Same exact situation I've seen, too. File transfers will pause, things will lockup, and then you just gotta give it time to go.
Even with the slow-down it doesn't make it unusable by any means, but it does run sub-optimally, for sure. The file system being in compatibility mode reeks havoc on things like virtual drive emulation, but who knows... These SOMs are fairly complex, so. I know there is some shared pins, for example, and however they do that sharing I haven't any idea.
