- enable all DLC […]
- enable all DLC
- copy in OBSE (script extender)
- OSR (stutter remover) ** note that you might need to alter the ini file for this if combat sounds are broken with the default.
- FOV modifier, defaults to 90, better at 95 so in the console type "set customfov to 95" and save game
- QTP3 Redimized 1.0 Patched-45666-1-0
- copy in zips from 'HD Texture' folder into 'Data' (this is the Oblivion 2020 Retexture Project mod)
- copy in and enable Enhanced Water v2.0 HD.esp
- copy in RAEVWD-20053-1-9-3.7z **need to do each subfolder, one at a time.
- enable the 2 .esp for this mod
- copy contents of Landscape LOD generator 5_15c-40549-5-15 into the Data folder
- run "tes4ll_highres.bat"
- run "tes4ll_normalmaps.bat"
- run "tes4_tes4qlod.bat"
- Loading Area Begone-49109-1-0-1548086503
- No Intro Videos-47255-1-0
- Better Blood v11-24448
- Better Blood Update v12-24448-1-2.7z
- CaptNKILLs NonTiling Texture Mod-4868
- Oblivion Scaling Unclusterfucked
- install Dousing The Flames-3974
- install 'Fewer Random Oblivion gates-3586' - I'm using NoRandomOBGatesEVER.esp currently
- install SlowerDegradation-35760-1-0
- Unofficial Oblivion Patch-5296-3-5-6a
- Unofficial Oblivion DLC Patches-9969-24
- Unofficial Shivering Isles Patch-10739-1-5-9
- EngineBugFixes v2.1-47085-2-1-1545922572
- copy in Trifle 21-44108-2-1.zip
- copy in Enhanced Camera-44337-1-4b.zip
- Natural_Faces
- THEN Facial Textures by Enayla-9534
- install Detailed Terrain - Beta II-15245.omod if you can be bothered, needs vortex. Does make the terrain look nicer
- Install archive invalidator (Installer Version - Recommended-10724) ** do the ini update required for this too
- Install DarNified UI 132 7z Archive-10763.7z. Just copy in the 4 folders, not custom files or docs.
- Make sure all .esps are selected under 'data files' in the launcher
- Install and run LOOT to sort mods
