First post, by Demo85
Been messing around with my ideal 98 machine. I wanted to run HDMI video out from it via the DVI port to a modern 1080p monitor. To keep things 4:3 I was thinking i'd output 1440×1080 but my 98 machine skips over that. I can do full fat 1080p but not 1440×1080. It's just not listed in display manager. Does anyone have insight on what the issue could be?
Reply 1 of 2, by agent_x007
You need to add custom resolution via PowerStrip/driver, as 1440x1080 isn't a VESA/"standard" resolution. Don't forget to disable scaling (or force GPU to scale).
Reply 2 of 2, by Demo85
agent_x007 wrote on 2022-12-22, 13:10:
So, I been playing with PowerStrip for a while now but can't seem to get any of my custom resolutions to go into effect. I was following this video on it https://www.youtube.com/watch?v=_BVVEFYB2wU but he kinda speeds over adding a resolution. Do you happen to know if a guide I could follow?
