First post, by Darko
I'm really deseperate to make this game working. I have original game, the version that came with all the other series games. I posted that some days ago but I get no help
Hello all!!
I need your help please. I'm trying to run Great Naval Battles 3 using DosBOx and DFend frontend, but every time I try to run, the DOS screen appear with the location of the game wrote at the bottom
C:/Archivos de Programa/GNB/GNB3
And nothing happens, If I try to press enter, the same appear again
I have no problems running GNB5, so this game have to work well no??
So any idea? Anyone have this game working?? And how please!
P.S. I believe that is a EXE problem, can someone send it to
capitanstratos at yahoo dot es
or by messenger at
capitanstratos1 at hotmail dot com
THANK'S
Reply 1 of 4, by milicognj
Hi Darko (or maybe Zdravo Darko). Here's the solution. DOSBox can not change to the directory called Archivos de Programa because it has a long file name which is not supported by DOS (name may have up to 8 letters).
Open game's D-Fend profile andd change the game path to the C:\Archiv~1\GNB\GNB3 and that should work.
Ognjen
Reply 2 of 4, by Worldtraveller
I'm trying to run this program as well and having similar issues. According to the tutorial on myabandonware.com, it looks like this should work, but the folder called 'VirtualHD" is more than 8 characters. Is this possible the problem?
I have gotten this program to run on a previous machine (also with WinXP) and don't remember having any difficulty.
