First post, by PhoeniX98
Hello everyone. I wanted to test some midis that i found on the web on my SC-55 mkII, and i found that some files sounds kinda strange. Is not the Capital Tone Fallback problem, my problem is more related to drum parts.
In this file http://www.vgmusic.com/music/console/nintendo … KC2_Mine-KM.mid for example, there's three drum parts, but the third drum part sounds as a piano, i didn't recorded it on the unit but i recorded it on SC-VA, where also is the problem. This behavior is strange and only occurs in Sound Canvas, because in the MS Wavetable sounds normal, in soundfonts and MU modules too.
There's a way to fix this without rewriting the file? Another Roland modules has this behavior too? For example, the SD-20, 80, 90?
Is not the only midi file with that problem, also there's these ones. All are GS-compatibles.
https://www.vgmusic.com/music/console/nintend … ghway-KM-GS.mid
https://www.vgmusic.com/music/console/sony/ps … /MM8TitleGS.mid
I attached audio files too.
