First post, by Marco
Dear all,
Is it possible to use more modern SCSI drives with above Adaptec ISA SCSI 2 50pin bus card (via active 80/68 to 50pin adapter)?
Why do I want that:
- newer drives are cheaper then real 50pin ones
- higher chance to get a non noisy drive
- newer drives are faster - with ISA bus at least seek time wise
I’m using a 386sx. I’m just tuning around and trying to get most out of it. SCSI in particular due to the cpu offloading.
PS: so far I found some diffuse hints that using the external scsi port could lead to most compatibility with new drives.
Thanks a lot
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@60 | 16MB | CL-GD5428 | CT2830| SCC-1 | MT32 | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
