Reply 120 of 209, by derpmochump
Tiido wrote on 2022-11-24, 12:58:
It is 3.x that is rotten, 2.1 is the good one that won't cause bunch of issues from being a mismash of newer DLLs that often break something.
what things in 2.1 are worth installing?
the whole pack? will it mess up my win98SE install? i don't want to reinstall anymore 🤣.
MSI MS-6734 KM3M mobo / Athlon XP 3000+ /512mb ddr1 ram
Voodoo 3 3000 PCI @185mhz / Aureal vortex 2 (dell oem)
3dfx ref. drivers win98se and dual boot with winXP-32 bit running amigasport 3.0 3dfx drivers oc'd with koolsmokey's V.Control in XP
Reply 121 of 209, by Tiido
I cannot really say anything certain anymore, it has been years since I last had to install things but I installed most options it gave on a frash install, after drivers had been installed. The "core updates" is the only thing that can really break anything as it updates a number of system components but almost all the updates it installes are ones you would have got from Windows Update anyway when it still worked.
Reply 122 of 209, by Joseph_Joestar
derpmochump wrote on 2022-11-25, 05:07:
I'll just point out that, if your main goal is retro gaming, then you don't need to add anything to Win98SE other than DirectX and the Windows Installer Update. Both of which can be applied as standalone updates. On the other hand, if you want to run some productivity software on your Win98 rig, that's a different story.
For people who absolutely must have Win98 up to date for whatever reason, I recommend using this official Security Update CD from Microsoft, rather than some cobbled together "unofficial service pack" of dubious quality.
That said, we're getting a bit off topic here, so feel free to open a new thread for tips on how to best set up Win98 for your use case.
Reply 123 of 209, by jaskamakkara
Hi, I am having some trouble with this using an SB0060. When I install the VxD drivers from the CTZAPXX.exe file: the installer runs and I get the prompt to restart but after the restart nothing has changed and the drivers haven't seemed to be installed. The whole multimedia/audio window is greyed out and I have no sound. I have a clean 98SE install.
One thing I noticed is that there are already 2 entries for IRQ 5 in the system information panel (SiS 7001 PCI to USB Open Host Controller and ACPI IRQ Holder for PCI IRQ Steering) - could this be a problem?
Thanks for any help!
Reply 124 of 209, by Joseph_Joestar
jaskamakkara wrote on 2023-01-07, 10:04:
The driver installation may fail if the card is unable to allocate enough free resources.
See step 1.4 of the guide for more details.
Reply 125 of 209, by jaskamakkara
Joseph_Joestar wrote on 2023-01-07, 10:32:
OK, but is there something I can do to rectify the problem? I am currently trying to redo the process with all my COM and Parallel ports switched off from the BIOS, but the Hardware information is the same for the IRQs so I am not confident it will be different. Maybe I should try with the USB disabled but I rely quite heavily on it for KB/Mouse/file transfer.
Reply 126 of 209, by Joseph_Joestar
jaskamakkara wrote on 2023-01-07, 11:14:
You could temporarily disable USB and use a PS2 mouse and keyboard until the sound card installation finishes. After that, you can try re-enabling USB again. Not sure if that will resolve your issue, but it should at least free up additional resources during the driver install process.
Another thing that comes to mind is to check if your chipset drivers are correctly installed (no exclamation marks in Device Manager) before trying to install the sound card drivers.
Reply 127 of 209, by jaskamakkara
Joseph_Joestar wrote on 2023-01-07, 11:29:
I tried everything with no luck. I think there might be something wrong with my hardware since I am sure I have done this process on that machine in the past. Maybe something has died... Probably best to pull it apart and see. Thanks for the help, anyway.
Reply 129 of 209, by Joseph_Joestar
jaskamakkara wrote on 2023-01-09, 06:37:
Yeah so I switched motherboards and now everything works just fine. Great guide, by the way.
Cheers!
Glad everything worked out for you with the new motherboard.
Reply 130 of 209, by Joseph_Joestar
Guide updated to version 2.1.
This minor update slightly expands the "Disclaimer" section. No new features have been added.
Reply 131 of 209, by Vanessaira
Hi, if I want to install this on my 400LX Slot 1 motherboard that has integrated OPL3 and 4 on board. How should I go about installing this package? Windows automatically sees these Yamaha chips on a fresh installation.
Thank you for this guide.
V
An Analog Girl in a Digital World
Reply 132 of 209, by Joseph_Joestar
Vanessaira wrote on 2023-01-11, 08:51:
V
I'm assuming you want to use the integrated Yamaha card for DOS games and the SBLive for Win9x games? In that case, it's pretty easy. Simply follow the steps as outlined in the first post, but stop right before section 5 - DOS driver installation. This will give you fully functional SBLive drivers under Windows, but without SB16 emulation for DOS games.
However, if you want to use both cards for DOS gaming, things get a lot trickier. That procedure is much more prone to failure, which is why I don't cover it in this guide, but it is nonetheless possible. If you want, I can give you some guidelines, but be advised that it's not very a straightforward process.
Reply 133 of 209, by Vanessaira
Joseph_Joestar wrote on 2023-01-11, 09:14:
V
Well, yeah, more or less I wanted the option to showcase OPL4 outside of Windows, but I also want the ability to select and use OPL4 within Windows 98 as well. I have plenty of Audigy 2s to do in other builds, and while I would like to try both in DOS as well. It is not as critical as having both in Win98SE.
V
Reply 134 of 209, by Joseph_Joestar
Vanessaira wrote on 2023-01-11, 09:26:
V
With the approach I mentioned above, the Yamaha card would remain fully functional under Windows as well. You would only lose the ability to run DOS games on the SBLive.
In Windows, you might need to select which of your cards should be treated as the "Preferred" sound device under Control Panel > Multimedia > Audio. Most Windows games will default to the card selected there, but you can change this at any time. You probably also want to select your default music device under the Control Panel > Multimedia > MIDI tab.
Reply 135 of 209, by Vanessaira
Joseph_Joestar wrote on 2023-01-11, 09:41:
V
Just out of curiosity. What is the "not so straightforward" approach to getting both to work in Win98SE and DOS?
V
Reply 136 of 209, by Joseph_Joestar
Vanessaira wrote on 2023-01-11, 09:44:
V
You would need to temporarily disable the on-board Yamaha card in the BIOS (or via jumper, whichever is applicable). Then, install the SBLive drivers as outlined in the first post, including the DOS component. Assuming the driver installation goes through without any problems (it might not) you would then need to right click on My Computer > Properties > Device Manager > Sound, Video and Game Controllers > Creative SB16 Emulation > Properties > Resources and uncheck "Use automatic settings". Then, choose "Basic Configuration 0004" > Change Setting.
This will allow you to manually change any settings except for the SBLive's Adlib port which will be disabled. You then need to ensure that the SBLive's resources don't conflict with the Yamaha. Basically, select something like A240, I7 D3, H7 P300 for the SBLive while leaving A220, I5, D1 P330 free for the Yamaha. Lastly, you would need to re-enable the Yamaha card in the BIOS/via jumper, as applicable.
Reply 137 of 209, by Vanessaira
Joseph_Joestar wrote on 2023-01-11, 09:55:
V
Yeah the Sony Vaio motherboard BIO has just a Legacy Sound option. Nothing via jumper and it looks like I will need to take it off the Use Automatic Settings for sure as to keep Win98SE from re enabling it after every reboot. Thank you again.
V
Reply 138 of 209, by Vanessaira
I seem to be stuck at the moment. I am to the part where you install CTZAPXX, but it only has WDM option selected. VXDs are greyed out. I am unsure where you want the VXD.cab file extracted. I extracted it all from the CD to the HDD in C: and made a folder where I put everything together including the CTZAPXX file and everything accompanying that on the CD into one location. I am using real hardware, real CDs etc.
V
Reply 139 of 209, by Joseph_Joestar
Vanessaira wrote on 2023-01-15, 09:43:
V
The contents of VXD.CAB should be extracted to this folder:
C:\AU1\Audio\Drivers\VxD
After that, CTZAPXX.EXE should be able to pick them up during installation. The fully populated folder should look like this:
40.31 KiB
It's weird that Creative decided that VxD drivers were such low priority at that time that they never bothered to decompress the archive on the CD. Not like it was lacking storage space.
