First post, by RockstarRunner
I know there exists power calculators for modern parts, to give you an idea what kind of power supply you will need, but is there such a thing for old 'retro' parts?
I'm putting together a build, and I'm wanting to use a Pico psu and 12v power brick combo, so I want to know what's the minimum I can get away with (it gets expensive as you go up in the watts department).
Anyone have a good idea what a P233mmx, 128 mb ram, onboard 2d VGA, voodoo 1, AWE 64 value, compact flash & a slim dvd drive, would require?
So, yeah, could I get away with 120W?
Edit: I found this thread, which has a few nuggets in it: Re: Total power watt of your systems
