First post, by Nexxen
- Oldbie
Hello lovely people,
I have a DIY h/s as I lack an original socket 4 cooler.
I'd like to get some data in order to locate an adequate and more stable (mechanically, as I use some metal wire - yes, it is a bad idea as it is conductive) substitute.
If you can post some pics with measures or just have a solution I'd be super glad.
Right now I use a socket 7 but it works if kept flat, no tower case 🙁
Anyway thanks a lot to all as always for the help and advice.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
