First post, by Ar2r4eg
I try to find 8bit universal VGA/EGA/CGA card for my turbo XT setup. I experimented with diferrent cards, and that is one of them
Marked as VGA Enhancer V8-512K REV.B based jn second generation Trident microsystems 8800BR video chip.
I can't find any information for this card and any drivers for it.
EGA out from this card won't work with my FPGA EGA/CGA converter and show almost non read, elongated and left shifted picture.
But i know that that card can run cga/ega emulation on vga out with utility SVM.EXE included in TVGAUTILfolder on driver disk.
All drivers which i can find in net from TVGA8900 chip, and don't work with my card.
Can anyone help with drivers for 8800BR or maybe SVM.EXE for that chp.
PS 8800-8900 drivers from vogonsdrivers won't work. Its for 8900.
My hardware:
enough for my wife to hate
Reply 1 of 6, by Grzyb
I've got a similar card, but haven't found a mode-switching utility.
I'm afraid the 8800 series doesn't support register-level CGA/Hercules modes at VGA frequencies.
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 6, by Ar2r4eg
Grzyb wrote on 2023-01-22, 15:22:
When Video bios init, on screen present text "VGA Mode" and in manual for similar card 8800CS present description about switching mechanism.
here - https://retronn.de/imports/hwgal/hw_trident_8800cs.html
But drivers from it don't work. Also config switches on my 8800br absolutely do nothing in any config.
My hardware:
Reply 3 of 6, by darry
TVGA8800BR is actually older than the TVGA8800CS, AFAICT . It is very hard to find anything about the BR variant's capabilities (or lack thereof). The newer TVGA8800CS was much more widely used and documented, again AFAICT .
Reply 4 of 6, by Grzyb
Ar2r4eg wrote on 2023-01-23, 13:20:
That manual describes "SVM.EXE" as the video mode utility.
But the drivers linked there are clearly for 8900 - they contain SVM89.EXE, which refuses to work with my 8800CS card.
Reply 5 of 6, by Ar2r4eg
Grzyb wrote on 2023-01-29, 15:55:
On ftp://retron.de/driver/Trident/TVGA folder placed 2 archives - UA63_DOS.ZIP and UX64_UTL.ZIP
SVM and other tools worked with 8800BR ftom it. In SVM you can choose different modes and test it, but can't apply it to adapter 🙁( pain...
My hardware:
Reply 6 of 6, by Grzyb
Ar2r4eg wrote on 2023-01-31, 16:15:
"Set Mode for Trident 93/94/96xx Families"
so, VLB/PCI era...
