PC Chips 754LMR+
Reply 40 of 58, by Nexxen
I tried my best but it boots and goes to garbage, you can still see something that indicates activity, Win loading etc.
Results show some improvements. I can't sort it yet 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 41 of 58, by Nexxen
Probably I need some option in BIOS that isn't there.
If I select 0MB of shared memory just garbage on screen. If I select any size it plays along well.
Sdram chips are lukewarm.
I'm running 3D99 640x480, 800x660 + 1024x768.
I think there is some improvements in the results. I'll post the file as soon as it ends the batch test.
Reply 43 of 58, by Nexxen
Ok, I can affirm that soldering 2Mx32, for 16 mb, works.
Instead of shared memory, it shows as "local buffer".
I couldn't launch 3D99, it was complaining something.
Unfortunately I resoldered a few legs and saw that the uber quality made some pads lift while cheking contact.
For the future masochist: soldering a SDRAM chip works.
I would have tried 32mb of ram but I can't and mostly I won't do this again.
With shared ram AGP is disabled, with soldered ram it shows @2x
    M754 hwinfo reports.7z
    8.79 KiB
    33 downloads
Reply 45 of 58, by Nexxen
Nemo1985 wrote on 2022-10-16, 19:10:
So any chance to make it work or no hope?
To make it switch to local sdram you need to select "none" at shared memory menu.
I should resolder everything back, but I don't have the drive to do it.
I lack a camera for precise micro soldering. Without it looks all good but in fact I got into trouble.
I can't find the adequate drivers, detonator don't work, other newer versions crash at OS loading.
And it's full of artifacts.
Yes, it works. SOldering sdram chips works, making it dedicated ram.
But I failed with soldering and I can't go redo everything.
I'm calling it a day and end this project here.
Reply 46 of 58, by Nexxen
While reinstalling drivers,
it works as a PCI device + shared memory;
it works as an AGP device + local memory.
A TNT2 + 16/32 MB of sdram @2x agp could be a good guess for results, if anyone wants to check thos of a dedicated graphics card.
Reply 47 of 58, by Nexxen
Pics
Reply 49 of 58, by Nexxen
Muzava wrote on 2023-01-25, 09:27:
You should redo the project, because it seems viable to have a 200 MHz SDRAM in that motherboard.
The core itself will OC to 180/185 MHz
I have still to try this mod in both of my PCChips M754MLR+.
I need a microscope to solder the ram chips and some pads are lifted: difficulty level is "high".
It's in a small, cramped area making it a slow and painful job. 😀
Overclocking features were non existent in BIOS IIRC. It bothers me I failed because it would have been a funny thing to benchmark.
Also, when I tried to resolder the chips on the VGA card it took them from, it would exhibit the same issues.
I killed a card and lifted pads... for a proof of concept not a great result.
But I smile anyway.
Reply 50 of 58, by Nexxen
Tin the pads, make them very fat to avoid loose legs. Check legs being aligned and touching the pads perfectly.
Hot air makes it fast.
BE SURE TO HAVE A BENT TIP for your soldering iron for touch ups. It's a huge work and time hungry.
I think I may have fried the chips with a too high temp, I used 350°C. No pre heating....
I was too hasty 🙁
Reply 51 of 58, by Muzava
Nexxen wrote on 2023-01-25, 11:27:
I need a microscope to solder the ram chips and some pads are lifted: difficulty level is "high". It's in a small, cramped area […]
But I smile anyway.
Yes, this motherboards have a thin PCB and that area have alot of tiny componentes and I agree that a microspoce is needed for this type of soldering.
The motherboard bios don't have a overclock option for the CPU, RAM and IGPU, but you can overclock the GPU with Coolbits register mod ir with the TNTCLK.
I haven't seen much difference in the 3DMark00 (like 30 points between 125 to 180), because the most percentage of performance of the graphics cards comes from the memory bandwith (that you can observe with FSB 66 to 100 to 133).
I have checked the PLL (Winbond W83194BR-39B) and it should have FSB till 150 MHz with jumper and software till 200MHz. It just a case of trying to make a jumper mod.
Also I noticed that R195 is connected to the CS of the SDRAM pinout.
Reply 52 of 58, by Nexxen
Muzava wrote on 2023-01-26, 00:04:
But I smile anyway.
Don't know what this is. Can you explain?
Reply 53 of 58, by JLPedro
Did this mod to my 754LR+ and I can confirm it works perfectly, local framebuffer 16mb on AGP 2x , ram I used is 166mhz.
This makes for a nice win98 system, with gfx and audio integrated, fast Pentium 3 and added bonus of an isa slot, at least on paper, don't know how stable this motherboard is.
Just need to test some games, also see if there's a more recent bios to this motherboard.
Reply 54 of 58, by Nexxen
JLPedro wrote on 2024-02-13, 17:57:
AWESOME!!!!!!!!!
How did you solder the chips in the motherboard? Air or iron? I think I may have killed the ram chips with air.
I am happy you could prove it is 100% working. I can't wait for benchmarks.
Congrats!!!
Reply 56 of 58, by Nexxen
JLPedro wrote on 2024-02-13, 19:14:
With iron, but still one pad lifted, the pcb is really fragile.
PCChips, PCCheaps it is 😉
Do you have pics of the lifted pad + repair?
Reply 57 of 58, by JLPedro
On the pic with the soldered rams its visible the bodged pad, right chip on the middle pins.
I think i saw one pic of this board with the rams soldered and a fan on the chipset from factory.
edit:
http://www.drivers.ru/catalog/motherboards/mo … FX_SB_7391.html
not the same model but same board/chipset
Reply 58 of 58, by Nexxen
JLPedro wrote on 2024-02-14, 13:27:
On the pic with the soldered rams its visible the bodged pad, right chip on the middle pins. I think i saw one pic of this board […]
edit:
I saw that, I meant the process of repair. Looks not that difficult though.
Anyway, great job! Basically the boards are all the same but some lack the ram chips, allowing onboard ram by just adding them. It's really unimportant but still fun to do and test 😀
I'm now pretty sure I damaged the ram chips using too much hot air while both desoldering and soldering to the mobo.
It was a long time ago and I've made my fair share of mistakes to learn from.
