HDMI To SVIDEO Adapter
First post, by rmay635703
My current cheap HDMI conversion solution allows me to under/over scan and move the image to center on screen, it outputs composite, Svideo and RGB+S (15khz) for old commodore / Amiga screens.
This was terrific for using my TV for Pc emulation amongst other things.
But sadly most other devices throw up HDCP errors almost immediately.
From what I can tell this pair of devices simply isn’t HDCP compliant.
Any ideas if there is a replacement device that will work like this but not cost an arm and a leg?
I like to keep my vintage content on the old Trinitron but all my ports are used up except Svideo.
Reply 1 of 5, by BitWrangler
It has always been one of the big "THOU SHALT NOT"s of HDMI that modern HD content can't go to an analog channel, hence HDCP fails when trying to use streaming boxes etc through analog converters. Therefore official HDCP compliant devices that do that, don't exist. Probably unofficial ones do, but they're the kind of thing that might get blocked at customs if ordering from overseas.
Reply 2 of 5, by digger
BitWrangler wrote on 2023-01-25, 20:58:
Didn't that only apply to "high definition" analog signals, such as YPbPr component video and VGA? Weren't converters to standard definition (and lower quality) analog formats (basically anything 480i and lower, including S-Video) exempted from that rule?
Anyway, if you can't find any HDCP-compatible HDMI-to-S-Video converters, you could try looking for an HDCP stripper and run the HDMI signal through that first. It would require two boxes instead of one, but it should work.
Reply 3 of 5, by rmay635703
digger wrote on 2023-01-25, 22:20:
That would actually be excellent because I could use my existing setup.
Most HDMI to composite devices don’t have over/under scan or alignment settings but my existing device does, only issue would be audio.
Aren’t HDCP strippers rather expensive though?
Reply 4 of 5, by BitWrangler
There was some exception somehow for OTA HDTV and blueray players, but never seen one where the source wasn't controlled.
Reply 5 of 5, by rmay635703
Going back to this topic years later…
I finally broke down and bought a cheap Walmart Onn hdmi to rca composite adapter. )it was a whopping $10) so onn 194346525027 (memorable model) doesnt work with roku
I have been told low res outputs don’t require HDCP and this thing lists all sorts of devices dvd, blueray, etc
but on Roku it’s even more nope than my homemade setup adapting the hdmi to vga and then scaling to the crt.
It doesn’t even get a signal (color bars flashing no signal )
let alone give an HDCP error, unfortunate, it’s easy to return but it will mean I need to go through the various Amazon devices until I find one that works.
More unfortunate is the last update removed the ability to set the Roku to 4:3 vrs 16:9
Onns adapter as usual works fine on pc, which is rather pointless for a device like this.
