Reply 47760 of 58192, by BitWrangler
If you're doing disk intensive stuff, it can be that even slow swap drives help, but memory intensive stuff favors putting swap on fastest drive. However, on balance, using something down to half as fast as your main drive is a speed up overall.
Reply 47761 of 58192, by Standard Def Steve
H3nrik V! wrote on 2023-01-25, 05:01:
BetaC wrote on 2023-01-25, 02:57:
pete8475 wrote on 2023-01-25, 02:41:
Awesome, the worst one!
Are there socket 423 SD-RAM boards? 🤣
Why would I want anything but RDRAM for a 1.3?
To experience just HOW slow the slowest of NetBurst could be 🤣
That title would belong to the 1.7GHz Celeron. The small cache *really* hurts Netburst, and it will be slower than a 1.3GHz full blown Willy in most tasks outside of audio or video encoding.
Plus, being a S478 chip, the Celeron can easily be paired up with PC133 memory, further amplifying the pain of only having 128K of 2-way set associative L2. 😜
"A little sign-in here, a touch of WiFi there..."
Reply 47762 of 58192, by H3nrik V!
Standard Def Steve wrote on 2023-01-25, 17:08:
Well, there's a 1.5 Celeron Willy too
https://www.cpu-world.com/CPUs/Celeron/Intel- … 31RC021128.html
[Edit]: Willeron? Willyron?
Reply 47763 of 58192, by H3nrik V!
H3nrik V! wrote on 2023-01-25, 19:12:
Willery? Ok, ok, I'll stop now 🤣
Reply 47765 of 58192, by Standard Def Steve
H3nrik V! wrote on 2023-01-25, 19:52:
Interesting, I didn't know they had a 1.5GHz/128K desktop variant! Must be an OEM part? I always thought that the 1.5 was a mobile-only CPU with 256KB!
Yeah, that would be one slug of a CPU.
Reply 47766 of 58192, by Ozzuneoj
I think Willyron (pronounced Willy Ron) has a nice ring to it. 🤣
Also, I'm pretty pleased with this purchase (sellers photos)...
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
Sticker on the computer says the system has a Paradise SVGA card of some sort. And that top card definitely looks like a mid-90s Sound Blaster...
Soo... after spending a little time comparing this photo to photos online...
The attachment 6a.jpg is no longer available
I determined that this computer absolutely has an AWE32 CT2760 (Rev. 1).
(pic from batyra.pl)
The attachment Sound-Blaster-CT2760-AWE32-Awers (Custom).jpg is no longer available
... and the VGA card looks to be identical to this fantastic Paradise WD-90C31 card, which is also an awesome score. I believe these do 16bit color, unlike the older models.
The attachment wdc_wd_90c31_lr_f (Custom).jpg is no longer available
I'm sure the board has battery damage and will need some work, but for the price I paid (especially after the shipping was adjusted by the seller) it was well worth it for these really nice parts, plus a really neat 486 ISA system that runs.
This detective work was a lot of fun. 😁
Reply 47767 of 58192, by pentiumspeed
Good catch. You'll like the WD video card so much, as good as fast Tseng but much more compatible and can do CGA or EGA emulation via VGA port iirc. You might have either WD90c30 or 31 as this shares same PCB, with no mods.
While on prowl, I found a reasonable but bit expensive Megatrends American pentium board, has 3.3V connector that I'm looking for long time, Most likely SiS chipset but well made board and 10W or more linear regulator in a monster TO-247 package bolted to an large heatsink, flat to the PCB surface, not the little T220 package on equally too small heatsink.
https://en.wikipedia.org/wiki/Small-outline_t … nsbauformen.jpg
Cheers,
Great Northern aka Canada.
Reply 47768 of 58192, by Ozzuneoj
pentiumspeed wrote on 2023-01-25, 23:03:
Yeah, it should be a great card! I'm about 90% sure it's a WD90C31 though, because all of the examples of WD90C30 I have seen have either a large SMD tantalum cap near the top right corner of the card or have a large through hole (tear drop shaped) tantalum there. Also, the C30s that look closest to this (with the long rectangular clock crystal and small square RAMDAC) are, I believe, made by DFI and aren't Paradise branded. The ones I have seen that say Paradise that have this exact layout are all C31.
I could certainly be wrong... but either one is fine for a fast DOS ISA card. 😀
Reply 47769 of 58192, by danieljm
Ozzuneoj wrote on 2023-01-25, 22:09:
I think Willyron (pronounced Willy Ron) has a nice ring to it. :lol: […]
Nice find! The thrill of the hunt and the investigative work is definitely a big part of it for me.
I don't know if it's like this everywhere, but as soon as you get any older than pentium era, I can't find anything like that around me. Well done.
Reply 47770 of 58192, by Ozzuneoj
danieljm wrote on 2023-01-26, 02:35:
Yep, my favorite part is the investigative work. The more years I do this the fewer surprises there are of course (both because of dwindling supply and just getting used to finding certain things).
Also, this wasn't local. It is pretty rare for me to find anything locally.
Reply 47771 of 58192, by Kahenraz
That's a really nice haul. I hope you got it for a good price. If you're this excited, I expect that it's true. You earned it!
Reply 47772 of 58192, by BitWrangler
There is a sharp kink in the adoption curve though, ~75% of 20th century PCs were sold between 1995 and 2000, the remaining ~25% was pre 1995. If 486 production had cut off sharp at release of socket 5 Pentium, then we'd probably only see as many of those as 386s, but they were selling as low end into the first couple of years of the boom. Also they remained useable until the web got java and flash heavy in the first years of millenium so were not junked super quick. 56k modems acted as enough of a bottleneck to hold back heavier web pages and keep it from being real obvious a 1Ghz PIII could browse the web much faster than a DX4-100 until mass broadband rollouts. In my estimate it kept 486es around 3 years longer than they might have been, affecting scrappage rate.
Anyway, what I'm saying is pre-pentium systems were only a third as common as post pentium, excluding the apparent visibility of 486es which had extended life into boom, so had their numbers bumped disproportionately and suffered less severe attrition at "EOL".
Each generation going back from there is also a smaller trapezoid in the area of the curve, 286 less common than 386 etc. Though numbers that were contemporary to the mid 80s get tricky because nobody had really really realised that IBM-PC compatible was it's own thing so masses of commodore 64s or Apple IIs might have got thrown in various statistics of "personal computer" sales, and it's not altogether sure that commodore didn't fudge their numbers outrageously.
Reply 47775 of 58192, by MMaximus
BitWrangler wrote on 2023-01-26, 04:26:
That's an interesting analysis, thanks for sharing. It's true that some of us were probably still using some DX4 machines at the turn of the millenium
Hard Disk Sounds
Reply 47776 of 58192, by dj_pirtu
Bought yesterday some stuff for my upcoming 486DLC-40 -system 😎
Reply 47777 of 58192, by psychofox
Just got for free this beautiful mainboard:
The attachment 20230126_073811.jpg is no longer available
Couple caps are gone bad, otherwise seems to be in good condition.
Reply 47778 of 58192, by Kahenraz
MMaximus wrote on 2023-01-26, 10:09:
I don't know enough about it too be sure, but I think that the Company Deskpro that I continued to use as my personal computer in my bedroom was a 486. I don't recall exactly, because I didn't know enough about computers at the time to open it up, and I don't recall the exact model.
It was pretty basic, and may have had Windows 95 initially. I don't know if it ever had Windows 98. It never felt slow at all. Although, time went on, I did run into problems with the tiny hard drive (250MB) and the video card (256 colors only) when I bought and tried to play Age of Empires. I had to delete everything I could find on my computer, even some of the larger junk files in my Windows folder, to meet the disk space requirement. I was so excited from watching the tiny little guys walking across the progress bar during installation. It crushed me when I got a dialog informing me that it would not run without a 16-bit graphics card.
I ended up installing and playing it on the family computer, which was a Pentium 2, I think with a Rage XL.
If my computer was a 486, I think I used it up through late 2000, if I recall correctly.
