So I got around to testing the advice of not doing orphinit.bat at start for when booting into Windows. But now I have a new issue (but of course). I have my Midi sound from my SC-55 routing back into the Line-In of the Orpheus II, but it seems like when I run a DOS game in Windows it doesn't utilize the line-in and no music passes through, digital sound works fine though. Also midi music does pass through properly in windows.. So I guess the windows bit works but the DOS in Windows bit doesn't now 🙁 It seems very strange the line-in works fine in windows but not in DOS mode in Windows but I am guessing DOS Mode in Windows must have a separate config for sound.. is there anyway to initialize the orpheus ii in just DOS mode in Windows?
Also to note, if I route the Midi audio from my sc-55 to the line-in on the Audigy 2ZS in Windows the midi audio comes through ok.. so its nothing to do with the midi output. Its just the line-in on the Orpheus II doesn't seem to initialize properly in DOS in Windows. Again, playing a midi when the line-in on the Orpheus II works fine in a windows media player.. its only the DOS in Windows Mode that doesn't work.
Update 1: Just decided to go back to running Orphinit when loading windows in the autoexec.bat file. At least when doing this the line-in works on the Orheus II in DOS in Windows mode games and I think overall I am not having any other issues right now. Will update if I run into any other issues.
