Reply 100 of 102, by BEEN_Nath_58
- l33t
Gamecollector wrote on 2022-12-28, 20:20:Tnx, looks like my 1st question was answered in this article. Use goldfxa.exe for correct 1.04F -> 3dfx patching... Failed. 1.04 […]
Njinsa wrote on 2022-12-28, 01:07:Few years ago I followed this guide and it worked , but as I favored LB2, can't recollect if there were crashes- https://www.pcgamingwiki.com/wiki/Jane%27s_Longbow_Gold
Tnx, looks like my 1st question was answered in this article. Use goldfxa.exe for correct 1.04F -> 3dfx patching...Failed. 1.04F + goldfxa.exe: the game starts, the main menu works but Instant Action fails with an error:
LBGold.JPGWell, lb104e.exe modifies flight.dle, objview.dle, tutor.dle, wrapdll.dle and deletes wail32.dll. If I copy these files from CD1 (the \GAME directory) -- then this will "unpatch" the game.
Tested: lb104e.exe -> "unpatch" -> goldfx.exe. The glide version works.
Under my testing, I come to the conclusion to install the goldfxa patch or 1.04 patch on the non-patched game. If I remember, goldfx -> 1.04 or vice versa crashed the game.
BEEN_Nath_58 wrote on 2022-12-28, 04:44:Additionally I had to enable EmulateHeap shim (this game works fine on Win11 22H2 fortunately) because the BACKDOORS/HEAP_PERCENT=0 setting IN CA.INI was still crashing in many occasions.
IIRC EmulateHeap is already enabled for lbwin.exe in the WinXPSP3 default *.sdb. EmulateCreateFileMapping, IgnoreAltTab and IgnoreException are enabled too.
[/quote]
Unfortunately, they were removed in Win8 or Win10. IgnoreAltTab is optional, the gam doesn't like Alt Tabbing so it's a stability measure. Ignore Exceptions fixes the initial video crashes, but it doesn't help in the latest Windows (thus remove movies1.tre, EmulateCreateFileMapping is important and it dodges an issue similar to the one you showed in the photo, but happening before the main menu.
