Reply 20 of 113, by Ydee
Yes, it´s PCCHIPS, branded as Matsonic (look at the rest of sticker).
Reply 21 of 113, by jnemo2004
Thank you very much!!!
Reply 22 of 113, by jnemo2004
Good afternoon (it's Spain). I have recently bought the Philips 5107-200-35233 motherboard and although it has oxidation in some parts it may work. I'm going to clean it with isopropyl alcohol and then I would like to connect it but it has two DIP switches and I don't know how to configure them. Does anyone have the manual? Thank you.
Reply 24 of 113, by jnemo2004
Thank you very much
Reply 25 of 113, by jnemo2004
Good morning, yesterday I connected the motherboard and a capacitor exploded. Can you help me identify the capacitor, it is the same as the one next to it.
Reply 26 of 113, by DAVE86
jnemo2004 wrote on 2023-01-30, 07:26:
The 226 marking tells that it is a 22uF 10V smd chip tantalum.
Reply 27 of 113, by snufkin
I think the 20K line says that they're made by Kemet and are 20V rated. Replacement doesn't have to be Kemet, just 22uF and 20V rated. Actually, depending on which voltage supply it's connected to then other voltages might also be ok. Not sure about the size, maybe 2917 (7343 metric, so 7.3mm long by 4.3mm wide). Something like this maybe: https://uk.farnell.com/kemet/t491d226m020at/c … HP-STM7REC-RP-1
Reply 28 of 113, by jnemo2004
Thank you very much.
It is a 7343.
Reply 29 of 113, by jnemo2004
Thank you very much for the information, I have already ordered the capacitors. I have a question to ask you, I will connect the motherboard to a VGA monitor but I am not sure how to put the SW2 switches (as indicated in the manual in a previous post). The plate has come with all closed.
Reply 30 of 113, by silencer_ar
Hello, I'm trying to identify this motherboard. I was able to find motherboards that look similar to this, but with a different pin layout (next to the memory slots). I'm trying to find the model/maker in order to try to find the manual and figure out what each pin means. Some of them have a label, but others don't. I still need to figure out the pins for the external battery, power on indicator and keyboard lock. Thank you so much!
Reply 31 of 113, by jnemo2004
Good morning (in Spain), could you please help me to identify this motherboard. Thank you very much
Reply 32 of 113, by W.x.
All you need to do, is to put "PC Chips TX Pro-II" into google, and viola...you go
https://theretroweb.com/motherboards/s/pcchips-m571-v3.2-a
it's obvious it is PC Chips, with "Burn-in" sticker, and also, by special chipset name Tx Pro, which only PC chips used.
https://hardwaresecrets.com/chipset-aliases-t … -vx-pro-and-co/
Reply 33 of 113, by jnemo2004
You are great!. Thank you very much.
Reply 34 of 113, by Chupperson
I need some help figuring out what this 286 motherboard is. It's almost identical to the Biostar MB-1212V except for some components on the edge near the ISA slots. Maybe it's just an earlier revision. Does anyone know what the logo on the serial number sticker is?
I actually found one on eBay but the seller doesn't seem to know any details about it either. https://www.ebay.com/itm/185759011221
Other very similar boards:
Shuttle 12MHZ ZERO-WAIT 80286 TURBO
DTK MBVLSI-168 (V.2)
They all have different jumpers on the side with the ISA slots and I haven't found any documentation with "JPA" and "JPB" listings yet. I just removed the battery and am attempting to make sure I have it set correctly for an external lithium battery. As far as I can tell, all I need to do is move JPA over (above the JP17 battery header) so it doesn't connect with the battery terminals but a little confirmation would be nice to have.
The attachment 20230206_234124.jpg is no longer available
Reply 35 of 113, by Deunan
Chupperson wrote on 2023-02-07, 06:07:
FYI not all mobos can be set to non-rechargeable battery. Most will accept one on the external battery connector but the way this is done is with an extra diode to prevent charging, but that in turns casues some additional 0.7V drop so the battery used needs to be 3.6V at least (usually up to 6V with 4.5V - like a 3xAA pack - being a good middle ground).
An alternative to the connector is to remove another diode, or the current limiting resistor, from the charging circuit. But on most mobos that will result in no power for RTC/CMOS even when running on AC, so the battery will be always drained. That too can be modded but it's no longer a trivial removal of one or two components.
TL;DR: There might not be a jumper to do what you want.
Reply 36 of 113, by Chupperson
After testing voltages on the battery header and changing the jumpers I suspected, it seems you may be correct in the case of this board, but it would still be nice to be able to find some documentation about it.
Not to get too off topic here, but if I'm seeing a voltage increase in sort of a sawtooth wave-type shape up to about 0.9v, would you call that normal charging behavior? https://www.youtube.com/watch?v=t1AgC6aCiP0
Reply 37 of 113, by jnemo2004
Hello, I'm here again.
Could you please help me to identify this motherboard (486)?
Reply 39 of 113, by jnemo2004
Thank you very much!!. Regards.
