First post, by brwyatt
This is (to me) an interesting issue, and may only be because I run Vista, but when MW2 is running full screen some of the graphics seem to lag. The main part in particular if the "initializing drop procedure" screen that has problems fading in/out (often times making you late to get into the game and in the case of many of the training missions, to crash into the docks). I also noticed that full screen caused some color issues in RA (but they weren't bad, and they usually didn't happen every time).
None of my hardware should be an issue, I would assume that the issue is either DOSBox or Vista in this case, but I have a 2.21GHz AMD Athlon 64 X2 4200+, 2 GB OCZ RAM, 256MB nVidia 7900GT.
when running MW2 it seems to take up 100% CPU, but that game is a CPU hog anyway and I believe that it is MW2 and not DOSBox.
I can live playing windowed (i could always switch to 800X600 resolution if i really need it larger anyways), but it cant beat the feel of playing it full screen!
Thanks in advance!
