Reply 20 of 31, by Repo Man11
- Oldbie
joeguy3121 wrote on 2023-02-08, 02:53:Thanks. I'm already thinking that the problem is how the seller installed the computer and what he included so I'll use the nusb […]
Repo Man11 wrote on 2023-02-08, 02:30:I don't know if it makes any difference in this case, but your motherboard is USB 1, so I would use the nusb33e driver instead. https://www.philscomputerlab.com/windows-98-u … age-driver.html
Thanks. I'm already thinking that the problem is how the seller installed the computer and what he included so I'll use the nusb33e driver when I do a 98SE install on a new 120GB hard drive, replacing my included 40GB hard drive.
Repo Man11 wrote on 2023-02-08, 02:43:On my 98SE computer, I have both nusb33e and the nusb36e drivers installed because I also have a USB 2.0 card installed. But I don't have an unplug or eject hardware box that comes up - I have the arrow in the system tray, when I click on it, it offers "Stop USB Disk - Drive(G:)" (or whatever letter it has).
I'm actually good with the USB 1 ports included on my motherboard. My only need for it is flash drives.
If the 2.0 ports on that card you mention make the transferring from the flash drive to the computer faster without being hampered by the old opereating system then I may consider it.
If makes things a bit faster, but that's not why I mentioned it. The Unplug or Eject Hardware box that you have looks like something from Windows ME to me, not Windows 98, and I'm not sure why it looks like that.
