First post, by AvocadoLongfall
I went and upgraded the i486 to a dx4 100 and the system posts though once it does it locks up and the keyboard stops working. The cpu I installed is an am486 100 WT
Reply 1 of 4, by Horun
Need more info. What motherboard ? Maybe you are overclocking the bus or the BIOS does not like the dx-100
Reply 2 of 4, by AvocadoLongfall
Horun wrote on 2023-02-10, 02:54:
It is a phoenix bios motherboard with version 4. The computer itself is a Zenith data systems Z select 100xe. Also, I am not overclocking the bus. I just installed an amd dx4 100 cpu.
Reply 3 of 4, by BitWrangler
Jumper 29 may be non obvious, I think you're gonna need it on 1-2
Double check that J32 is set correctly for 3.3V
Reply 4 of 4, by AvocadoLongfall
This I believe is what I am supposed to set it to according to the manual of this motherboard for the computer.
I even attempted to set the jumpers as what you suggested but to no avail.
So I was able to return the cpu back to the seller for a refund so I can obtain a chip that should not be defective.
