AMD K6 3DMARK, aiming for stars.
Reply 460 of 560, by doogie
Over 5k!! Nicely done and looking forward to the writeup. I love it
Reply 462 of 560, by Oerg866
Could be a really nice idea! makes it easier, my solution for now is a fat wire between 3.3V from PSU to the closest capacitor, whilst also massively increasing the capacity of it + adding a big fat ceramic cap inbetween 😀
Sadly this is the most I can do, if I increase GPU core / mem by even one single MHz it starts artifacting. No 5400 for me I guess 🙁
Reply 464 of 560, by Oerg866
The last result was with a Gainward GeForce 3 Ti 200 😀
Reply 465 of 560, by Necrodude
I have been thinking about one thing. Is it possible to use the BIOS chip from a ASUS p5a on a Gigabyte ga-5ax?
I have both at P5A and a ga-5ax. I have noticed that the ga-5ax can run higher bus speeds on then the p5a board, but it is slower. Could it be the BIOS?
Is the BIOS on a p5a better then the BIOS on the ga-5ax?
What do you guys think?
Reply 466 of 560, by Sphere478
Necrodude wrote on 2023-01-01, 23:25:
I have been thinking about one thing. Is it possible to use the BIOS chip from a ASUS p5a on a Gigabyte ga-5ax? I have both at P […]
Earlier in the thread someone modded the gigabyte bios. Flip back a bit and check it out 😀
Sphere's PCB projects.
Reply 467 of 560, by Skalabala
Oerg866 wrote on 2022-12-21, 17:41:
Could be a really nice idea! makes it easier, my solution for now is a fat wire between 3.3V from PSU to the closest capacitor, […]
Thats an awe score! Can you raise the FSB? And is the 1024kb cache fully working on rev E chipset?
Reply 468 of 560, by Oerg866
Skalabala wrote on 2023-02-19, 04:15:
Thanks!
1. No, sadly any higher FSB and it becomes very unstable
2. Yes, it is fully working 😀
Reply 469 of 560, by Skalabala
Remember that using win95 gives you a 30-50 point boost 😀
Reply 470 of 560, by Oerg866
I'm using 98Lite which already gives me the boost 😁
Reply 471 of 560, by SWZSSR
Hey all
Was inspired by this thread a few years back.. finally got around to building up my ASUS p5a system.
My CPU score seems to be low compared to my friends MVP3 system running identical specs..
-- Specs --
K6-2+ 570 modified to K6-3+ @ 6x100
ASUS P5A Rev1.6 ALI-G *Resistor Mod to Fix Slowdown*
2x128MB Infineon PC-100 CL2
MSI Geforce2 TI 64MB (7.76 driver reporting as GTS)
Onboard ESS SOLO-1 Audio
--Drivers--
- ALI 1.82 AGP
- ALI IDE 3.56
- 7.76 Nvidia
- Windows 98SE, DX7
- ALI AGP Registry Tweaked
- BIOS Tuned
- NO other tweaks yet..
--3DMARK 99 Score--
-4754 3DMarks
-8336 CPU 3Dmarks
--3DMARK 2000 Score--
- 4315 3DMarks
--Bios Settings--
--Resistor Mod--
5TH / Dual 233MMX / Millennium II 8MB / Voodoo2 12MB
P5A ALI-G / K6-3+@600 / Geforce256DDR / EWS64XL
Thunder 2500 / Dual P3-S 1.4 / 7950GT AGP / Audigy 1
M919-3.4bf / 5x86@180 / Banshee-PCI / Soundscape Elite
AX4GE-Tube / 3.06HT / FX5950Ultra / Tube Audio
Reply 472 of 560, by flakes
Nice...
My score on a shitty VIA system
System
EPoX/ProNiX EP-58MVP3C-M
128MB PC133 SD-Ram
K6 Mod III 600
Geforce 2 MX 200
Reply 473 of 560, by kempy24@bigpond.com
This my score of my Microstar MS-5169
System
Microstar MS-5169
128MB PC133 SD Memory
AMD K6 III Mod to 600Mhz (Original was AMD K6 II 570 Mhz Before MOD)
Creative CT6970 (NVIDIA Riva TNT2 Ultra)
Reply 474 of 560, by Skalabala
SWZSSR wrote on 2023-04-13, 06:42:
Hey all
It does seem slow. Wonder why, your 3dmark 2000 should be close to 5000.
Reply 475 of 560, by Necrodude
Hey all Was inspired by this thread a few years back.. finally got around to building up my ASUS p5a system. […]
Hey all
-- Specs --
--Drivers--
- ALI 1.82 AGP
- ALI IDE 3.56
- 7.76 Nvidia
- Windows 98SE, DX7
- BIOS Tuned
--3DMARK 99 Score--
-4754 3DMarks
-8336 CPU 3Dmarks
- 4315 3DMarks
--Bios Settings--
--Resistor Mod--
I also have a P5A board with a k6-3+ 400mhz cpu @616 (112x5.5)
I get 5K points in 3dmark 2000. I am using a Geforce2 Ti gpu.
I have used WPCREDIT to get a nice boost in the scores. I am using WPCRset to load the settings at the startup.
here is my settings
I am also using CTU and a couple of other nice little programs to get some extra juice.
Reply 476 of 560, by lukas12p
WPCRset valuas are typical for ALi boards?
What is CTU?
Reply 477 of 560, by Necrodude
lukas12p wrote on 2023-04-23, 12:48:
What is CTU?
I really dont know. I guess some of the settings are. I copied some of the settings from another vogoners YT video.
The other settings are done by lots of hours trial and error.
CTU stands for central tweaking unit, and can be found at
https://www.philscomputerlab.com/k6-2-2-3-resources.html
I am using a couple of the tools found on that page.
Reply 478 of 560, by lukas12p
Thanks
Reply 479 of 560, by Mentat-vvo
flakes wrote on 2023-04-13, 10:09:
Nice... […]
Nice...
System
128MB PC133 SD-Ram
K6 Mod III 600
Geforce 2 MX 200
It’s not the VIA system.. replace the user and Stryke.. )
PPro250/Freeway694x/512M/Gf3Ti500/AdvGUS
2x P3Xeon900-2M/1Gb/QuadroDCC/AWE32
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
