First post, by _astriid_
New to the forum and relatively new to DOS (been getting into it only this past year)
I recently grabbed a Compaq 1130T laptop on the cheap and decided to make it my DOS machine. There's no sound card so I figured I'd use my SC55MKii to run midi out of the serial port when playing games like Doom. Only problem is, I can't seem to get the two to work together 😅
I'm running DB9 from the laptop to DIN8 in the SC. I can get midi to communicate between the two with Voyetra SPG but anytime I try running Doom, I can't get them to communicate.
I'm running MSDOS 6.22. I've tried running softmpu to no avail.
CONFIG:
The attachment 20230222_213052.jpg is no longer available
AUTOEXEC:
The attachment 20230222_213249.jpg is no longer available
What's the point in being grown up if you can't be childish sometimes?
Reply 1 of 3, by Cloudschatze
I've patched a handful of protected-mode drivers and executables for RS-232 MIDI output that can be used with your serially-connected SC-55mkII. Here is the relevant post concerning DMX-based titles, such as Doom:
Re: MPU-232 : RS-232 MIDI interface, compatible with SoftMPU
Reply 2 of 3, by Cloudschatze
Status?
Reply 3 of 3, by _astriid_
Cloudschatze wrote on 2023-02-23, 04:53:
totally forgot to check this out sorry! been a busy couple of months 😅
This worked beautifully!! Thanks so much for this, it's just what I needed
