First post, by tpowell.ca
Hello.
I was wondering if any of you knew how to remove what appears to be autogenerated parts of the PATH pointing to your Windows 9x installation folders?
Even if I redefine the path, Windows folders always precede whatever I define.
Thanks
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 1 of 3, by Grzyb
I don't know if they can be completely removed, but they don't have to precede others - just include "c:\windows;c:\windows\command" in the "path" statement in AUTOEXEC.BAT, eg.:
path c:\aaa;c:\bbb;c:\ccc;c:\windows;c:\windows\command
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 3, by Azarien
I think the Windows folder is set in msdos.sys (it's a text file in DOS 7.x)
Reply 3 of 3, by tpowell.ca
Yeah, but if possible I want to remove them completely from the path for specific configs.
If I decide to boot into windows 98, I can't break MSDOS.SYS.
Grzyb's suggestion could work, but there must be a way to bypass that completely.
I wonder if that feature/annoyance is built into COMMAND.COM
