First post, by LieboOSBA
Following on from a different thread, my Packard Bell iConnect uses a Houston4 motherboard.
I suspect it would be Windows 98 or even Windows Me given its age is around 1999-2000.
I was wondering if anyone has the recovery media for such a system? If so, can you provide a link or maybe upload it to archive.org please? I can only find one similar in Dutch, but I would prefer one in English please.
LBX Computers
Reply 2 of 9, by dionb
Green iConnect? Then it's an eMove series system with WinME, from late 2000 or 2001.
You need a 3-CD Master CD set for it, and it needs to be newer than your system (although with Houston motherboard any eMove set should be OK). Don't have it though, I'm afraid, and I'm not sure I'd be allowed to share it if I did.
Reply 3 of 9, by Tetrium
Was this the 3 CDs that looked like they had a first aid logo look-alike on the disk and were these 3 disks each a different color?
Though even if I still have them, these were most likely also the Dutch version. Or perhaps I'm mixing something up here now, I always found those days of royalty OEM install media rather confusing (except for the Fujitsu Siemens ones, I always liked their XP-era install disks).
It would perhaps be a better idea to use a generic Windows install from a standard 98SE or ME install disk.
It should work just fine. Pre-WinXP doesn't require any activation either and generic drivers should also work.
Or is wanting the original royalty OEM disks part of the retro experience you are seeking?
Btw, may I ask you if you could please edit your last reply in this thread you linked to earlier and edit (not post a new reply but edit the existing reply so it doesn't get bumped) it by adding a link to this thread?
My retro rigs (old topic)
Report spammers here!
Reply 4 of 9, by LieboOSBA
Tetrium wrote on 2022-05-31, 15:11:
Was this the 3 CDs that looked like they had a first aid logo look-alike on the disk and were these 3 disks each a different col […]
Yes I am looking for the 3 CD set, in English as part of the Retro experience I am seeking.
I've edited my last post to link back to this thread too, thanks.
LBX Computers
Reply 5 of 9, by BomfunkAnDs
Did you ever find them?
LieboOSBA wrote on 2022-06-10, 21:42:
Reply 6 of 9, by LieboOSBA
No I didn’t unfortunately
BomfunkAnDs wrote on 2023-02-27, 15:49:
LBX Computers
Reply 7 of 9, by BomfunkAnDs
LieboOSBA wrote on 2023-02-27, 18:34:
I will keep my eye out for them too and let you know if I find anything. I do have the red floppy disc with the first aid cross and an ambulance on it, but no CD!
Not sure where to start searching, but will!
Reply 8 of 9, by LieboOSBA
Thanks so much 😀
LBX Computers
