Hello,
I would like to setup 3x sound cards based in the following specs:
Mobo: ASUS P3B-F v1.04 Intel 440BX motherboard Slot 1 [2x ISA slot variant]
CPU: PENTIUM III 500Mhz SL37D
Graphics AGP: MEDION MSI GeFORCE4 TI 4200 128MB DDR SDRAM AGP
Graphics PCI: Voodoo 3 2000 PCI
Soundcard PCI: Yamaha YMF724-V AC-XG
Soundcard ISA: Creative Labs Sound Blaster AWE64 value CT4520.
Case: InWin H500 desktop case
Current OS = Win98SE, but intend to use MS-DOS later on]
Currently both sound card have been installed, and since I like the sounds of the Yamaha I decided to set it as the default, hence had to fiddle with IRQ settings and changed IRQ, DMA etc with those of the Creative 64.
Now, regarding the 3rd sound card I am intending to use the WP32 MCCAKE with a raspberry pi.
Question 1:
Which raspberry pi model is recommended that does the job ?
Question 2:
Would it be possible to use music from WP32 MCCAKE. and Sound Fx from Creative AWE64 for example ? And if so, should I get some type of KVM switch with audio [3.5 jack] to output SFX and Music through the same set of speakers ?
Question 3:
How can I set the WP32 McCake parts, I would like to put it inside the 5.25 drive bay enclosure, is that possible ? Serge from Serdaco already sent me this info but am confused.
"hi
you will need a waveblaster header on one of your soundcards
then mccake can be used in combination
-->please check your Creative AWE64 ISA, and Yamaha YMF-724 PCI if one of them has the waveblaster header
if not you could add a 3rd card, mpu card for mccake. (i can refer you to the right person to get this with mccake)
best regards
Serge"
Sorry to bombard you here with these questions. Am still learning and grasping ideas from various posts etc, coming from Amiga computers background here.
Thanks in advance!
