First post, by GabrielKnight123
I put a Pentium 133MHz supporting both socket 5 and 7 into an Asus PCI/I-P54SP4 rev 1.4 socket 5 motherboard only to find out it wont post with the full 133MHz instead its a bit shy at 100MHz. The manual says this:
66MHz (100) ....xxx jumper setting
60MHz (90) ....xxx jumper setting
50MHz (75) ...xxx jumper setting
40MHz ...xxx jumper setting
Note: CPU's are normally listed by their internal clock speed, shown in parenthesis above
I set the jumper to 66MHz because the CPU is a Pentium BP80502133 133MHz, bus speed 66MHz, clock multiplier 2, processor core P54CS, core voltage 3.3V, isn't 66 x2 = 132 (133MHz) why does this happen? Is there a way to get it to 133MHz?
