First post, by GloriousCow
I come seeking advice for how to implement what I thought should be a fairly straightforward emulator feature - I'd like to be able to set a breakpoint on DOS program start.
I know I can run a debugger under emulation, but it would be nice if I could just pause the emulator at the first instruction of a new program run from command.com. I can sort of do this knowing that the first program I run after boot will usually be loaded at a specific address assuming the machine parameters and DOS version are the same, but it's a hack and only works for the first program run. For DOS 3.3, for example, the first program will usually get loaded at 0CA2:0100. For DOS 5.0, it's 0F19:0100. I'd really like something that didn't rely on magic numbers.
int21h, 4b (https://stanislavs.org/helppc/int_21-4b.html) seemed like a promising place to start. But it doesn't seem to return while the process is running.
Stanislav's lists int21, 55h (https://stanislavs.org/helppc/int_21-55.html) as an undocumented interrupt that sets up a new PSP. It says it is valid from DOS 2.0 and on, but I don't actually see it called on either DOS 3.3 or 5 when logging all interrupt 21h calls.
All I really need is some reliable way to determine the code segment of the new process after int21h, 4bh is invoked. Any ideas?
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 1 of 8, by superfury
Well, DOS transfers to segment:100h after loading the binary and setting up it's data/stack segments (although for .COM executables only. .EXE have it in their file headers, which are dynamically allocated).
In UniPCemu, you can specify a breakpoint with just an offset, making it ignore the segment part of the breakpoint.
Just add O to the breakpoint segment:offset.
UniPCemu Git repository
Reply 2 of 8, by Calvero
Just use the command "debug prog.exe"?
Reply 3 of 8, by GloriousCow
superfury wrote on 2023-02-19, 09:53:
That's an elegant solution for COM files. Don't know why I didn't think of it. Shame it won't work for EXE files, but at least that will help me debug MUSHROOM.COM.
Reply 4 of 8, by llm
its not clear what you are trying to reach?
debugging of DOS exe or com programs can be done using:
-(very archaic) using the debug command from a real MS DOS: https://en.wikipedia.org/wiki/Debug_(command)
-using the dosbox internal debugger (much better then the real DOS debugger): Guide to the DOSBox debugger
-Turbo Debugger from Borland or WD Debugger from Open Watcom V2: https://en.wikipedia.org/wiki/Borland_Turbo_Debugger, https://github.com/Baron-von-Riedesel/HX-OpenWatcom-Debugger
-serveral other DOS-able debuggers - but i normaly only using the dosbox debugger for my reversing projects
maybe you don't know that there are so many working debugger solutions for DOS or i didn't understand you questions
but for understanding a (maybe small) COM program like MUSHROOM.COM the best option is a disassembler like IDA Pro or Ghidra, im always using my licensed version of IDA for reversing and re-assembling of DOS programs
Official IDA Pro 5 Freeware: https://www.scummvm.org/news/20180331/ - the only Freeware Version that supports DOS EXE/COM
the song playing thing?
Reply 5 of 8, by GloriousCow
llm wrote on 2023-03-03, 07:04:
I'm writing my own emulator. I would like to be able to drop into my emulator's native debugger when a program starts. I am aware I can debug inside the emulated machine, but that's not exactly what I'm looking for.
Reply 6 of 8, by jmarsh
Write your own .com that calls int21.4b with al=1 to load the program to be debugged, then jump to the new ip with the trap flag set (or some other method to notify your emulator to break).
Reply 7 of 8, by llm
jmarsh wrote on 2023-03-05, 00:02:
jmarsh idea is the best i think - you can't activate a debugger by just hooking some interrupts because you're then too early in the process
but some sort of "preapre for debug" program that that loads (and not directly executes - as jmars explains) with int 21h/4b/al=1 combined with some control-handover to your emulation (using interrupts, ports, whatever to let your emulation know that it should start the internal debugger) is i think the only good or always working solution
Reply 8 of 8, by GloriousCow
Thanks, I went with this method and it works pretty well. Now I'm wondering if I couldn't intercept calls to 4bh and actually change the parameter of AH to 1, then intercept the write to the parameter block.
execute:
mov ax, ds
mov word [pb_cmdline_seg], ax ; Fill out data segment for command line param
mov ax, word [cmdline]
mov word [pb_cmdline_offset], ax ; Fill out offset for command line param
mov ah, 4bh ; EXEC/Load and Execute Program
mov al, 01h ; Create program segment prefix but don't execute
mov dx, fn_buf ; Point to filename
mov bx, pb_env_seg ; ES:BX to parameter block
clc
int 21h ; Execute
jnc success
jmp fail
success:
mov ah, 09h
mov dx, execute_ok
int 21h
mov ah, 01h ; Emulator service 01h = debug program
mov bx, [pb_cs]
mov cx, [pb_ip]
int 0fch ; Emulator service interrupt
jmp exit
Appreciate everyone's suggestions!
