PowerVR Fun Thread
Reply 1040 of 1105, by Gamecollector
IIRC F1 Racing Simulation from Ubi-Soft supports glide and d3d only.
P.S. Any SGL game imports sgl.dll functions so has "sgl_create_screen_device" in the dump. Theoretically...
Reply 1041 of 1105, by DigiMind
JustJulião wrote on 2023-03-03, 20:32:
Wow I've never seen this.
Can you play at a lower res. and tell if it changes something ?
Generally speaking, stay away from S3 cards for PowerVR gaming, it's among the slowest. Verite is fine.
Squares scale with different resolutions, so they definitely have the same size in pixels and yeah, these are tiles 😁
Will read PVR architecture reference to understand how it's possible (really, more likely I would have expected squares at a fixed point in the screen space than in 3D)
320X240
55.06 KiB
512X384
57.42 KiB
640X480
61.67 KiB
1024X768
61.33 KiB
Reply 1042 of 1105, by DigiMind
I have an idea.
Broken tiles are simply unlit ones. Don't remember how is lightmapping realized in Q1/Q2 engines, but this is a "multi-texturing" issue.
Not sure how can (for example) be broken part of the chip core (ALU, tile-processor etc.), so maybe after all this is VRAM issue.
Very fun glitch 😀
Reply 1045 of 1105, by JustJulião
Kahenraz wrote on 2023-03-03, 23:34:
Has anyone thought about pairing a PCX2 with a PowerVR Kyro? It just seems like an interesting and logical pairing
yes
I made tests in games too but not documented it. I remember it to be quite good and having good compatibility.
Reply 1046 of 1105, by JustJulião
New toys for my PowerVR card
405.32 KiB
149.05 KiB
169.65 KiB
I've only found videos of PS1 versions of Enigma and 3D Shooting Maker, none of PowerVR ones, so I'll make some gameplay videos sooner or later.
Unfortunately, 3D shooting Maker's menus rely on system fonts, meaning my american release of Windows can't display them corectly. I guess I'll have to install a japanese version of Windows.
Reply 1047 of 1105, by leileilol
It's a good idea to install a japan windows anyway as there are some games locked to the system language and refuse to run or install otherwise. I have a Japan Windows ME setup for exactly that (also.... me-tan )
Reply 1049 of 1105, by JustJulião
Kahenraz wrote on 2023-03-08, 03:43:
Is it possible to get them working by copying over a few DLLs? I think that works for Windows 3.11.
Not in a simple way, but it should work using a soft called NJstar communicator. But I can't find one of the Win9x compatible versions. It's not on the Wayback machine at least.
leileilol wrote on 2023-03-08, 02:58:
I heard it also includes english, is it true ? I would use Google lens for things I don't know by heart but it's not the best experience (I was about to make my own 3D shooter this way 😁).
Reply 1050 of 1105, by SteveC
Hi, I've read a lot about Techland's MiniGL driver but I can't actually find anywhere to download it?
Reply 1051 of 1105, by leileilol
It's not really a dedicated download (an older version used to be available as a download back in 1998), but rather it's found in Techland's Crime Cities game, and the demo is the easiest way to get it.
Don't expect miracles though. It doesn't try to substitute blends like NEC's PowerVR Extreme driver, and is still missing some vital GL functions (especially regarding depth ranges, clipping and mipmaps)
Reply 1052 of 1105, by SteveC
leileilol wrote on 2023-04-08, 23:51:
Thank you 😀
Reply 1057 of 1105, by Kahenraz
I don't know at that speed it bottlenecks from the CPU, but leileilol is right. A Voodoo 1 is going to be much faster in most games, and has the best compatibility. The only game I can think of where the PCX2 really outshines the competition is Mech Warrior 2. And I think that's only because of really buggy implementations for all of the other renderers. The Voodoo 1 makes an especially terrible showing here, despite its advantages.
If you already have a fast processor, you'll see much more of an effect by overclocking the PCX2 by replacing the clock chip. The performance uplift is almost linear.
Overclocking the Videologic PowerVR PCX2?
Reply 1058 of 1105, by rasz_pl
1024x768 30 fps Tomb Raider on P233MMX is another gem https://www.youtube.com/watch?v=5GMesT4WKzI going up to 1GHHz P3 doesnt change anything as the game is locked to 30
Reply 1059 of 1105, by JustJulião
Bought a rare version of the PowerVR PCX1
1.68 MiB
Chadti99 wrote on 2023-04-17, 22:55:
Whats the perf gain look like between a p3 1GHz and a p4 3GHz? Surely it’s minimal?
I'd say something between 5% and 10%.
I personally dislike using it in a much newer system, but if you want to get the most out of it, it will be slightly faster that way.
Make sure to not use a S3 or SiS primary card, it's slow with a PowerVR.
Finally, I made a PCI bus speed comparison with an overclocked PCX2 (90MHz).
Quake I :
29MHz : 34.1
39MHz : 34.6
video
System is a 440BX board with a Celeron Tualatin 1300.
The primary card is an ATi Rage 128 Pro (AGP).
PCI bus speed relevance is clearly overated, even with a 90MHz card. At least on a 440BX motherboard.
As a bonus, here is Tomb Raider 5 runing on a PCX2 @90MHz . I know it was an old engine when it came out in 2000, but I found satisfying to play a 2000 game smoothly with a PCX2.
Sorry for the dark image.
