First post, by red_avatar
I'm building a Pentium III system which currently has a Voodoo 3 3000. Ideally I'd prefer to drop the Voodoo 3 and instead get a GeForce 3 or 4. These are quite costly these days however but I found an interesting deal for a HP Nvidia Quadro4 750 XGL which is basically a GeForce 4 Ti 4400 - an ideal card for later Windows 98 games (combined with a Pentium III 1Ghz)
The thing is, the seller mentions the card does not support OpenGL which seems odd to me - he mentions Furmark giving an error but I assume this is because he's using a more recent version? From what I can find the card supports OpenGL 1.3 from 2001 which seems OK to me? Not many games are likely to require OpenGL 2 under Windows 98 SE.
So is this card recommended for this use case? I have zero experience with Quadro cards so was curious if it had certain limitations in terms of gaming.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 1 of 9, by Jura Tastatura
I've been using Quadro980XGL (ti4600 on AGPx8 bus) in my P4 W98 rig with no problems whatsoever. All games and benchmarks running smoothly and without errors.
Reply 2 of 9, by Ozzuneoj
I don't remember Furmark being around Prior to the DirectX10 era (after 2006), so it was likely never intended to be run on something as old as the Geforce4\Quadro4 series with DX8.0\OpenGL 1.3 level features.
The oldest reference I can find to Furmark online is a forum post about it back in 2007... 5 years after the Geforce4 series was released. The oldest cards that I see tested are DirectX 9\OpenGL 2.x level hardware like the Radeon X300 and Geforce 6200 series.
So, I would say this is a case of a piece of hardware being tested with the wrong software.
Reply 3 of 9, by red_avatar
Jura Tastatura wrote on 2023-03-08, 13:44:
That's good - I've been wanting a good 3D card again and they're pretty hard to find in working condition. They sure don't make 3D cards to last very long and all the lower end ones are absolute garbage.
Retro game fanatic.
Reply 4 of 9, by red_avatar
Ozzuneoj wrote on 2023-03-08, 13:59:
Yeah I figured that - I never used FurMark because it was dubbed "the card killer" back in the day due to it overheating cards so easily.
Retro game fanatic.
Reply 5 of 9, by TheAbandonwareGuy
So, sometimes when a GPU is not working correctly but not fully bricked you can get a weird issue where the driver loads up and works under 2D but will report the card has zero 3D capabilities.
This being said Furmark latest is OGL 2.0 and up only, IIRC 4Ti cards only support OGL 1.4. So Furmark probably wouldn't have been useful anyways.
How expensive is this card? If it's under say $25 I'd say roll them bones. I would not pay more than $30ish. 4Ti 4200s regularly sell in that price range and every single one I've owned OC'D to at least 4400 range fine. I'd only pay $50+ for a 4600 or 4800 or the Quadro equivalent.
As for if it's good for Win9x, it should absolutely annihilate any workload from 2000 or before. The 4Ti and FX5200s are IMO the best bang for the buck you'll find for Win9x. In my experience Quadro cards usually perform nearly identically to their normal brethren, sometimes even a bit faster in OGL. Once in a while you'll find a game that doesn't like the high precision float these cards use but it rare.
It's also worth noting that IIRC you can desolder and move one single resistor, reflash the card with a 4400 BIOs, and turn it into an actual 4400. It's the same silicon running with different optimization preferences in the vBIOs and driver.
Reply 6 of 9, by red_avatar
TheAbandonwareGuy wrote on 2023-03-08, 21:22:
So, sometimes when a GPU is not working correctly but not fully bricked you can get a weird issue where the driver loads up and […]
Nice, thanks for the heads up!
Retro game fanatic.
Reply 7 of 9, by Repo Man11
I have a Quadro 700 and I made a thread about the issue I had: Quadro 4 700 doesn't work with Windows 98 SE
Reply 8 of 9, by red_avatar
Repo Man11 wrote on 2023-03-08, 21:38:
Thanks - I think I know what your problem was by the way. These cards were often shipped with workstations from Dell or HP and the BIOS on these cards were specifically designed for THEIR motherboards and only tested on THEIR motherboards. It's no wonder some motherboard worked and some didn't. When you flashed the BIOS you probably applied some bug fixes that made it fail on some motherboards.
Retro game fanatic.
Reply 9 of 9, by Repo Man11
red_avatar wrote on 2023-03-09, 11:19:
I concluded that the original BIOS wouldn't work with AGP 4x and Windows 98. AGP 4x and Windows XP worked, and AGP 2X and Windows 98 worked, but AGP 4X and Windows 98 wouldn't work until I updated the BIOS. I realized that the reason it worked in the PCChips P4 motherboard after I used the contact cleaner is that the oil in the contact cleaner increased the resistance and caused the board to put the card in 2x mode - when I removed it and cleaned the card again it bumped it back into AGP 4x mode where it again wouldn't work with Win98. The card has worked fine in every motherboard I've tested it in since updating the BIOS.
