Hi, I just tested the latest ver. SBEMU from github but it doesn't work on my system (in signature) with SB Audigy1. Anybody else had a success on a SB card?
It detected PCI device SB Audigy but after messages that "RM and PM support: enabled" it beeped from speaker and ended with "Internal stack overflow, System halted" message and push HW reset button was necessary. I loaded JEMMEX and HX from the SBEMU package. Any idea waht to try?
UP: I tried run it also without JEMM/QEMM - just himem and it halted too.
BTW what should numbers 00:00:00.000 mean? A soundcard PCI bus/dev/func address? Then it shouldn't be all 0...
should be:
PCI device #24 found at bus: 6, dev: 0, func: 0
Vendor ID: 1102h (Creative Labs)
Device ID: 0004h, Revision ID: 3, Class: 04h (multimedia device)
Sub-Class: 01h (audio device)
DB name: EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series]
IRQ: 19, INTA, Cache line size: 0 Bytes, Latency: 32, max 5us, Status: 0290h
BAR: 0000FFE1h, 00000000h, 00000000h, 00000000h, 00000000h, 00000000h
ROM base: 00000000h, Cardbus CISptr: 00000000h, Subs.VID: 1102h, Subs.ID: 0053h
CMD: IntDis-,FB2B-,SERREn-,WCC-,PER-,VGAPS-,MemWIEn-,SCE-,BusMa+,MemSEn-,IOSEn+
