First post, by another_808286
I recently picked up an old external cdrom and I found that the drive inside the casing was the creative cr-563b; I intend to just take the drive out as use it for an internal drive in an old system. However, I couldn't find much information on what exact model this external enclosed one is or what the db37 connectors would have original gone to. (Note that it seems as though internally, there is nothing more than a dumb adaptor board linking the 40 pin and the db37, it does seem that the db37 also carries power though.) My question is: is it at all worth keeping the external enclosure for any reason, is it actually useful in that the db37 connector goes to something, I don't think I have ever seen it on a sound card.
Here are some pictures of the drive in the enclosure: https://imgur.com/a/FHSEUKV
Reply 1 of 5, by BitWrangler
It possibly came with a matsushita single speed drive in at first and got upgraded to 2x.
Reply 2 of 5, by wbahnassi
That drive is 2x and connects to a SB Pro 2 CT1600 and requires the MKE driver. I have one similar to it but missing its plastic faceplate 😑
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 3 of 5, by JidaiGeki
That’s the original drive in its case - I have one but it got a bit beaten up in the post. It should connect to the CT1810 controller card, of which there are some available cheap on eBay. It is also 37-pin and has an audio connector as well to mate up to your drive.
Edit: I see you have the cable! Awesome.
I wouldn’t discard the enclosure as these are fairly rare, haven’t seen a second one and there is sparse record of them online either.
Reply 4 of 5, by another_808286
JidaiGeki wrote on 2023-03-11, 13:45:
Ok, thank you, good to know. I will keep the enclosure in that case. Since the db37->40 pin creative interface adaptor seems to be a "dumb" adaptor that does nothing more than pass through the pins and inject power, would it be possible to find or make an adaptor that could convert the creative drive interface on something like an AWE32 to the external db37 port?
Reply 5 of 5, by BitWrangler
You probably just need a D connector on a bracket with a 40pin ribbon wired into it, and power to floppy or hdd connector... keep the ribbon as short as you can though to avoid problems. Tie all the ribbon grounds to ground though even if you run out of 1:1 connections on the D.
