First post, by kotsoskorg
Good afternoon,
I've got this laptop with a fresh installation of windows7 starter. Can someone offer enlightmen concerning its hardware? I want sound, network and modem drivers for this model. Truth is, I searched a lot on model number, serial and/or other keys according the backpanel tabs but the total search returned no related result. Any help could help a lot, thanks in advance. Below, I attach you some usefull snapshots.
Reply 1 of 5, by CharlieFoxtrot
I have no clue, but that might be some generic laptop designed by companies such as Clevo or Sager, for example, and just sold by some other company with Plato brand. Searching old laptops from those companies might yield some results.
Reply 2 of 5, by Horun
It looks like an Airis. One forum (https://www.biosflash.com/e/bios-help-1781.htm) lists same exact 755IAO as a Airis N619. Also this for sale site: https://www.olx.pt/d/anuncio/computador-portt … eo-IDzZpQB.html
The Airis website www.airis.es and the support site www.airissupport.com is in spanish.
did find some manuals and some drivers thru archive org but only for Win98 thru XP, not sure if the same laptop but no WIn7 drivers listed.
attached n619 brochure....
edit: found the 755 brochure but no drivers...attached
Reply 3 of 5, by DerBaum
If i have problems finding drivers i try to identify the missing stuff from the Device Manager. The Hardware IDs give a pretty solid starting point what you need. Just put them in google and it should at least tell you what the hardware is.
The attachment hardware ids.png is no longer available
FCKGW-RHQQ2
Reply 4 of 5, by dionb
Or alternately, just open it up and look at which chips it has. I find that's frequently the fastest and most fool-proof way.
Reply 5 of 5, by ediflorianUS
sound card : https://drivers.softpedia.com/get/SOUND-CARD/ … io-Driver.shtml
some older xp here : https://www.driverguide.com/driver/detail.php … riverid=1452198
seems to be intel chipset so use the one you like from here
some intelGMA drivers that may or may not have 855....
(PS. if you think that laptop is old , look at mine- this b&w prototype from '91 - 1991).
My 80486-S i66 Project
