First post, by AlessandroB
I have always used to check Western Digital disks (large from 250GB to 3TB and beyond) Wester Digital software called "Data Lifeguard Diagnostic" but sometimes I perceived that it was not reliable as I could hear the disk making strange noises but at the same time the software told me that there were no errors… maybe the software only checks the possibility to read the sectors and from the vaults the continuous reading noises return a correct reading value?
Reply 1 of 17, by ediflorianUS
use hirensboot cd dvd it has evrything you may need. MHDD and Victoria , HDAT2 , vivard , etc , if you think your plate PCB is coroded , after hdd is cooled down , clean it , let it dry and remount , for main pins contacts on pcb, you can use a pecil's eraser , and for full pcb-board you can use contact cleaner. may help for many things and interruptions. (saved a 1TB samsung recently, had crud on main contact to pcb that was not visible).
My 80486-S i66 Project
Reply 3 of 17, by weedeewee
the only benefit with using official tools is that they will often give you an error code that you can use to request an RMA.
That aside. the only official tool I had some confidence in, in finding a faulty drive was the samsung tool I once used for testing a 4GB drive.
All other tools I used at some point in time just tend to rely on the hard drive firmware smart status tables and to show they do something just do a linear read on the drive.
Some have the option to do a Read/write/read test, it's better than nothing I guess.
Some tools allow you to do a secure erase.
But mostly the tools rely on the drive to tell the software if the drive is still good or not.
If you hear the drive make odd noises, chances are high that it has some or a lot of "relocate" sectors.
Victoria is a great tool. Just getting the timing info on the sector reads can tell you a lot about the state of a hard drive.
Do not ask Why !
Reply 4 of 17, by rasz_pl
While I have no experience with WD tools, afaik Seagate SeaTools doesnt use any proprietary protocols and relies on SMART and good old read/seek tests.
Reply 5 of 17, by verysaving
Weedeewee is right, Official tools are just to check if drive is for RMA.
With Victoria and MHDD you can get lot of info on the health of the drive,
but if you want to get really inside it, download WDMARVEl demo from the
link below and take a look at the internal defect lists of the drive.
Since it's a demo you are allowed only to read from the drive, so, theoretically,
can't do any damage, but BE CAREFUL because some commands are active even
in demo mode and it'a matter of a click to render a good drive a brick!
https://wdmarvel.com/en/
This could be helpful too :
http://www.hddoracle.com/viewtopic.php?f=117&t=1393
Reply 6 of 17, by Zup
Just use MHDD / Victoria / WHDD. They read every block on disk and "time" every operation and show the results. Up to "green", usually is fine. "Orange" or worse means that a problem is developing in that zone, even before SMART catches that. A disk with "orange" blocks is not reliable.
Also, keep an eye on smart statistics... look at how many reallocated sectors (or pending reallocation sectors) has the disk and if it has increased before and after running one of those tools. SMART won't trip until those parameters reach a threshold, and sometimes that threshold is higher than desirable.
I'm selling some stuff!
Reply 7 of 17, by ediflorianUS
you can reset relocation table , after disabling smart , then format all with MHDD or HDAT2 (don't remember exactly). on old hdd-s I just use a 486 or previous to save it . (if not seen on more modern controllers than dos checkdisk-it to save the error mess). However try a smell of pcb and pcb clean before doing anything else , may have a failing part on the pcb.
Reply 8 of 17, by AlessandroB
I downloaded Victoria and it looks great, I prefer graphical interfaces over dos for equal functions and victoria seems pleasant to use. Basically I just check if the drives are trustworthy, when they start failing they are untrustworthy and trash them.
Reply 9 of 17, by Zup
AlessandroB wrote on 2023-03-14, 22:28:
The advantage of victoria is that it can test USB disks (USB support in MHDD does not always work). The disadvantage is that "timing" of the blocks depends on CPU load. If your CPU is busy (i.e.: another program is working hard) it will register as longer reading times, so it will be less accurate. You can see that the first time a test is launched: some blocks will be "green", but if you stop some 5 seconds later and relaunch the test those blocks will appear as "grey".
BTW, I consider:
- "Green" or better safe (unless there are many "green" blocks).
- "Orange" are dangerous. Make a backup now, don't use that disk for anything important.
- Failed blocks: make a backup, then trash that disk.
ediflorianUS wrote on 2023-03-14, 11:00:
IMHO, not a good suggestion. "Recovering" a disk via HDAT2 only hides the problems and some people may think that the disk is reliable again. You will only squeeze some time before that disk fails again... and your data will be gone.
Reply 10 of 17, by AlessandroB
Some result… what you think? Is smart reliable as a test? should it be used together with the block check or is it redundant and does it matter more to do the block check?
    361.61 KiB
    489.75 KiB
Reply 11 of 17, by ediflorianUS
Zup wrote on 2023-03-15, 05:58:
The advantage of victoria is that it can test USB disks (USB support in MHDD does not always work). The disadvantage is that "ti […]
BTW, I consider:
It's for personal use on vintage stuff you already have on dvd's or backed-up . or archive web page. if you use it daily than no. I suggest not using windows apps only dos and not over USB , just on pc mb controller.
Bad hdd's never sit at 21C/23 C they never go under 35C, never, that hdd seems to be in great shape , you may need to reset the smart because of the many errors , reseat the PCB on back of hdd and disable smart from bios if you can. You are good to go. if you like win apps just try hdd tune on quick if it has many problems it will have red squares than you can stop testing. And I suggest change-ing the SATA cable of hdd. it may have caused the errors. Or SATA controller. if not than the PCB has crack joining's on data signal transmission edge of the SATA port and bettwen pcb.
Reply 12 of 17, by rasz_pl
AlessandroB wrote on 2023-03-15, 08:47:
both look fine, you can run whole disk read scan manually or initialize internal SMART self tests. Dont know if victoria can do this, but https://hddscan.com does under tools/smart tests/short or extended.
Reply 13 of 17, by AlessandroB
rasz_pl wrote on 2023-03-15, 20:30:
Are you sure? Victoria say "unideal" in one of the two HD, the other one is rated "good".
Reply 14 of 17, by weedeewee
it probably says that due to the hardware ecc recovered entry in the smart table.
Can't recall if I mentioned it but smart entries aren't foolproof.
Sometimes a bad cable can cause smart failures to appear.
Do not ask Why !
Reply 15 of 17, by rasz_pl
from experience some drives just generate a ton of internal crc errors while working fine
not to be confused with dma crc, those re cable related
Reply 17 of 17, by ediflorianUS
for a full reset you can use the MHDD / HDAT2 or PartedMagic - DiskEraser*will reset the disk.
Victoria & Vivard-for scan also good (dos version) but not as great as above apps.
