theamtrakvirus wrote on 2023-03-19, 02:38:neither version seems to detect the cpus.
Without seeing screen shots I can't sensibly comment. I would need to see both the initial screen and the CPUID data.
Looking at the screen shots I noted:
- For MSR 0000002A the Cur 0C should be 0F, 0C means x2 which is why the BIOS reports 266 MHz which is 2 x 133 MHz
- For MSR 0000002A the Max 0F is x6.5 which is as it should be
- For MSR 00000017 the Multiplier 0F is the speed the CPU is specified to run at it's x6.5 which is as it should be
- The 1.73GHz comes from 532 MHz * 6.5 / 2
- The TSC is running at 532 MHz when it should be 266 MHz, this is why the FSB is reported as 266 MHz and the memory 800 MHz
- I am sure the TSC is @ 532 MHz as there is no dilation on [CPU Timers]
- Given 525 / 878 * 866 = 518 clearly the CPU is running @ 533 MHz and I suspect the multiplier is x4 even though it's reported as x2 and the BIOS thinks it's x2
The bottom line is that the CPU seems to be reporting x2, is x4 when it should be at x6.5. Given it's reporting 0C rather than 0F then I guess two pins are in the incorrect state, but I don't know enough about how the processor and motherboard communicate the multiplier ratio to use to know which pins these are.
In the BIOS is there a screen that allows the CPU speed to be set?
When I looked in the save file at [SMB Bus] I noted that [ 0_63 ] + [ 0_64 ] have very high peak times so SIV should not try and read them. I have adjusted the attached SIV32L 5.70 Dell-00 test SIV to skip them so use this rather than SIV 5.69. It should also report the CPU and MB temperatures, does it?
SIV was unable to read the RIMM SPD, do any programs report the SPD and if so which? I expect there is an SMBus multiplexor as the system supports eight RIMMs and wonder if the SPD would be reported if you moved them from RIMM2_A to RIMM3_B or RIMM4_B. Were it my system I would install all 8 RIMMs, then if the SPD for 4 was reported start toggling GPIOs in the hope one controlled the mux.
