First post, by psz
Tried running Civ1 DOS with and without VDMSound. Tis too slow. So I figured, "Ok, just use Speedset, try some test speeds, get it correct." And I did. .025 seems to be perfect... Except that when I tried to use it in conjunction with VDMSound's AdLib it crashes with
CIV.EXE
The NTVDM CPU has enountered an illegal instruction.
CS:4f1d IP:8713 OP:0f 0d 15 01 19 Choose 'Close' to terminate the application
So... Any ideas as to wether this is a Civ error, Speedset error, or VDMSound error? :->
(Tried posting this in the speedset forum, but it kept erroring out 😜)
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
you know that civ1 is slow from it self ?
no matter how fast your pc is. Civ1 is always slow......
I was suprised by this fact myself actually. Expecially the speed with which the units move. It's irritating slow ( i ran it on a pII 350 in win98 dos)
But as DOSFREAK said it runs perfect in Dosbox.
Qbix
Water flows down the stream
Reply 3 of 6, by psz
Yes, it is painfully slow (though speedset fixed THAT problem).
Civ1 now runs perfectly in DosBox with AdLib support! Woot!
(Now I just need GM support >:->)
Yes. I am greedy. Hear me whine ;->
Reply 4 of 6, by Unregistered
I use CIV The Old on an old (too) PC 486 66 Mhz and with Win 3.1. And that's slow... if I launch it through Win. Launching it from DOS makes it absolutely fast - and I refer to the movement of the troops too, which is surely slow in the first example.
Hope this will be helpfull...
Reply 5 of 6, by Kurt
Hello All,
What is speedset?
Where do I put .025?
Trying to get Sid Mier's Civ1 (Dos) to work with WinXP pro.
Any help would be greatly appreciated.
Feel free to e-mail me.
- Kurt
kurt_holman@hotmail.com
Reply 6 of 6, by Nicht Sehr Gut
Originally posted by Kurt What is speedset?
Speedset is a slowdown tool for games that DO NOT use "protected mode".
You follow the example given on the Speedset page.
Use DosBox.
...or not. Since we already have our hands full here, chasing people down to give them info isn't on our list of important things to do.
The whole idea of the board is the public exchange of info that all can use. Private emails defeat that purpose. They are saved for personal exchanges.
