Reply 160 of 1120, by PC@LIVE
- Oldbie
I'll be back briefly on the Soyo 5BT5, for the moment I'm working on the ABIT SE6, but I also have the Gigabyte AM2 waiting (hopefully soon), these two jobs at the moment have precedence, but I'll put my feet back on the SOYO (later), I'll see fix the cache chip with a missing pin.
Among other things to do there will be the change of CPU, with a dual core, initially I would use a P.MMX, but the final goal is a 400 or 450MHz K6-2, so for this last frequency it would be very usefull The setting with the 32MHz PCI (instead of 37.5), unfortunately with the P.133 (P54) doesn't work, but could it be a CPU problem? -I have no idea- But I hope so.
Just for the record, the frequency generator is an ICS 9148BF-04, on I.N. I found a pdf where besides the normal combinations (shown on the MB), there are three other secret ones, one works and it's the one called 68.5MHz Turbo, currently I use that instead of the normal 66.7MHz, while the other two are for 75 and 83.3 with PCI at normal frequency (32 and 33.3), therefore a divisor greater than 2, of course if the non-functioning of those settings does not depend on the type of CPU, it is strange that they used that "generator", above all because I found that it is used on other S.7 motherboards, in particular, I found one on an ACorp 5VIA5S, but strangely on the serigraphs of that card there are not those two secret settings at reduced PCI speed.
I'd find it a little strange that they don't work there either, I wonder why put that generator if you can't have those particular settings available, here's the next step I'll do is look for the manual, maybe I'll find some info on the CYRIX settings, because I think serves above all to those particular CPUs, I remember that the first 6x86 P200 went 150MHz (75X2), this was a frequency that not all the cards of the period supported, furthermore the PCI worked at 75/2=37.5 frequency which could create problems, I did a 75/32= calculation resulted in a divisor of about 2.33, this allows for high FSB and normal PCI operation, I think it is very reliable and faster (than 66.7).
However, just to see I put some pictures of this card, taken from one on sale, the price is high for me, now it's been a long time since the prices have gone up, you can find cards that don't cost much but usually have some problem operation.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
