Reply 40 of 1119, by RayeR
- Oldbie
Nice, we discussed about this with Tiido and others 3-4 years ago
PCI sound cards and Chipsets from various manufacturers...
and finally someone made it 😀
It's not clear to me, or I overlooked it, where Rasteri connect LDRQ# signal from to his adapter. All MBs that I met has not routed LDRQ# to TPM header - of course, why would TPM chip needs a DMA transfers for a tiny amount of data. So it need to be hacked out of the MB, mostly possible way would be to locate SuperIO chip and tap a pin there. SuperIO may use DMA for LPT port in ECP mode and floppy so it could't be used at same time.
I would be happy to blow off the dust from my bought Fintek bridge and build a copy of the adapter.
I bought mine from Ali but no longer avail from this seller https://www.aliexpress.com/item/32839231409.html
LSS10999 wrote on 2023-03-26, 12:43:By the way, it seems the executable I built with DJGPP (actually cross-compiled from Linux) doesn't run when JEMM386 is active. It outright pagefaults. Running in real mode (without JEMM386)
Hm, this must be some specific linux crosscompiler issue as I normally use DJGPP for my tools (native under DOS) and all runs fine under EMM/JEMM/QEMM386 as well as only himem and bare RM...
For the initilaization there would be another possible way. If some one is hardcore in ASM enough, he can make init code as PCI option ROM - feel free to use my ROMOS as a starting point: http://rayer.g6.cz/romos/romose.htm
I already have a simple hack that enables VGA16 decoding in my chipset to fix bad Gigabyte BIOS bug in PCI option ROM together with ROMOS....
