First post, by Mamba
Hello all,
Sorry if I ask something already assessed, but surprisingly I do not see consistent answer to this question.
Do the VP6 works with two P-3S Tualatins?
Of course with adapters or modified.
I saw now and then that there is chance it works only one.
Thanks
Reply 3 of 8, by PcBytes
It might actually work though - VP6 uses VIA 694, which should be easy to get Tualatins to work in. With adapters of course.
Reply 4 of 8, by Mamba
PcBytes wrote on 2023-04-07, 10:40:
This is what I was thinking, lot of other boards work.
Like CUV4X-D
But it works only one cpu.
Any owner/modder?
Reply 5 of 8, by nd22
I have several VP6 and none of them can take 2 Tualatins. I do not own an adapter but a friend that has them tried one and it did not worked. They are running just fine with dual Coppermines 1ghz. That was one attempt only and there was with the 2 processors with adapters at the same time; there was no attempt with just one CPU so I do not know if the boards work with a single processor.
Reply 6 of 8, by The Serpent Rider
It's important to specify which type of Tualatin. PIII-S can do SMP, while regular PIII Tualatin and Tualerons might not.
Reply 7 of 8, by Mamba
The Serpent Rider wrote on 2023-04-13, 07:09:
I always assume we are talking about S of course…
But I am having a hard time to find a modded bios with microcodes at least.
Nothing on the net.
Reply 8 of 8, by PcBytes
Albeit it might not be much relevant - what about the Coppermine-T models?
