First post, by ancanar
Hello.
I am running this game on Win7 and everything seems fine but only on some resolution. Any higher than 1024x768 drastically lowers the game performance. Everything looks very bad especially "smoke" effects when force power is used. You can also clearly see the issues in the main menu on the rotating JK series logo. I vaguely remeber simmilar issues with "smoke" effects from the old days when the came came out. Anyone knows why higher resolution is causing it and if there is a way to fix it?
