First post, by cookertron
My motherboard has one set of these retention bracket blots but as it's dual slot 1 I need another pair, any idea what they're called and where I can find them?
Thank you,
Anthony
Asus P5A v1.06, Gigabyte GA-6BXDS, Soyo SY-5EMA (faulty), Viglen 486, Asus SP97-V
Reply 1 of 5, by PD2JK
I would source them from a donor board. Also the cheapest I think.
Reply 2 of 5, by cookertron
PD2JK wrote on 2023-04-11, 16:52:
Seems a bit extreme just for two of whatever these things are 😒
Anthony
Reply 3 of 5, by Minutemanqvs
Slot 1 (I guess, Athlon is the same kind) CPU retention bracket?
Edit: ebay has the top parts, but the bottom parts are usually glued to the mainboard so apparently rarely sold...
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 4 of 5, by cookertron
Minutemanqvs wrote on 2023-04-11, 17:19:
Strange, the ones I have are loose.
Maybe I could make a couple somehow.
Reply 5 of 5, by Minutemanqvs
You don’t really beed them, just a bolt with some protection for the mainboard PCB (paper) will do for testing and playing with? What you need is the other side to hold the CPU in place.
